The Motorola Droid 2 is a rather durable device on its own, but does that mean that you want to carry it around unprotected, leaving it exposed to the elements and potential damage? If you are someone who likes to protect your device with a slim, stylish, professional looking case, the Seidio Innocase Surface may be a good choice for you. Let's look at it a little more after the break.
This case, which is made of a hard plastic with a thin rubbery coating over it, is a rather durable, low profile, and adds nearly no weight to the device. The rubber-style coating on the device not only adds protection in case the device was dropped, but also allows for better handling while the device is in your hands. The case itself adds next to no bulk to the device, and after about 10 minutes of use I could barely tell that it was still on the phone.
While the case is on the slim side, it does not lack in build quality in the least. The tabs that hold the case to the device are sturdy, so if you need to remove and install the case there should be no worries about potentially breaking one of these, as long as you are reasonably careful. On the case that I have I did notice that the back piece had a little bit of vertical play, meaning that the case was able to slide up and down just a bit, but it did not feel as though it would fall off, or shake itself loose. The cutouts for the headphone jack, volume rocker, and the charging port allow for easy access whenever usage is needed.
If you are looking for a nice solid, slim, professional looking case the Seidio Innocase Surface is a great choice for you. For $29.95 from the Android Central Store, the protection and style added to your device by this case makes it money well spent.
- Filed under:
- Tags:
932(forum posts)
