If you can't answer your doorbell from your phone yet, you are doing 2019 wrong. Correct that with this great deal on a Ring Video Doorbell Pro. The certified refurbished devices on sale at Woot are offered for just $129.99 exclusively for Amazon Prime members. Considering that refurbs normally sell for $224 directly at Amazon, you're saving almost $100 if you buy at Woot right now. Each doorbell has been inspected and tested to ensure it looks and works like new and, like all Amazon refurbs, it's backed by a one-year Amazon warranty.
When ya gonna ring it?
Your Prime membership almost pays for itself with the savings on Ring's 1080p video doorbell. Put it to use and add some extra security and smarts to your front door.
$129.98 $224.00 $94 off
With the Video Doorbell Pro, you can see who's at your front door in glorious 1080p using the free Ring app, and even interact with them right from your phone thanks to two-way audio. You can also set it up to send you alerts as soon as motion is detected or when visitors press the button. There's even two-way audio so you can interact with whoever is at your door and night vision so it works great around the clock.
You'll need to have an existing hardwired doorbell in the place you want to install this one. Installation is really simple and should take less than 15 minutes to do yourself. This deal is only available for the next few days — or until sold out — so be sure to log in with your Prime account and place your order while you can.
We may earn a commission for purchases using our links. Learn more.
