The BigBlue 3 USB ports 28W foldable outdoor solar charger is down to $50.99 on Amazon. This solar panel normally sells for around $60 to $65, and today's deal is its lowest price in more than a year.
The power of the Sun!
Like Superman, you, too, can increase your power by absorbing the sun's rays.
$50.99 $65.00 $14 off
The BigBlue solar panel is compact and lightweight and designed to fit in your backpack and on the go. It has three USB ports and can detect what devices are plugged in to give them the fastest charge possible. With enough sunlight, the solar panel can convert up to 23.5% of the solar power. You also don't have to worry about getting it damaged because it can survive rain and fog. All the ports are covered to protect them, too. Use the attached micro USB cable for Android devices and cameras. It comes with a two-year warranty.
We may earn a commission for purchases using our links. Learn more.
