It's been a while since we last a Trapster update but clearly they were hard at work while we waited. Today, they've gone ahead and released v3.0 to the masses and if you're a current Trapster user you should be pleased with the changes:
- Speedomoter and Speed Limit Display - Trapster now displays your actual speed with the speed limit of the road you are currently traveling on. If you go 1 to 4 MPH over the speed limit, the “Your Speed” box will change to yellow. If you are driving 5+ MPH over the speed limit the “Your Speed” box changes to red, visually alerting you to slow down!
- Trapster Widget - Now you can have Trapster on your home screen! This gives you the ability to quickly view and vote on traps, and also launch the Trapster application directly from the widget.
- Terrain Maps - In addition to standard map and satellite view, you now have the ability to use Terrain maps, this will display elevation levels in much more detail.
You'll also find that Trapster has a new UI with a much cleaner look over previous versions, making it easier on the eyes and even easier to read when in use. The v3.0 update is available now, you'll find the download past the break.
- Filed under:
- Tags:
105(forum posts)
