The Motorola Droid X is a a looker to be sure. And to properly show it off on your desk or bedside table, you're going to want to check out the Motorola Multimedia Desktop Charger. But it's more than just a way to keep your Droid X charged.
The Motorola Multimedia Desktop Charger also will serve up high-definition video from your Droid X to your television, via a port in the rear of the charger. You'll have to provide your own HDMI cable, though. But it does come with a lengthy microUSB charger, so you'll have no problem keeping your phone juiced.
The dock itself is a matte black plastic.There's a large, metal bar that extends about halfway up the rear of the phone, to keep it from falling out and damaging the microUSB and HDMI ports. It also has a magnet that senses the Droid X nearby and launches the multimedia desktop mode (more on that in a second). The bottom of the dock is made of a nonstick rubber, so it won't go sliding around your desk.
The Droid X sits sideways and automatically switch into a special multimedia desktop mode when inserted. You get a big clock with the date, weather info, plus easy access to alarm settings, a dimmer button, and music and photo icons.
The Motorola Multimedia Desktop Charger for Droid X is available now in the Android Central Store for $39.95. We've got more pictures of it in action after the break.
- Related devices:
- Filed under:
- Tags:
2438(forum posts)
