With its pivoting arm and ball-and-socket joint, the Clingo Universal Hands-Free Mount is a great way to keep your Android phone in place, and easily visible in any vehicle. The sticky pad holds any phone securely while keeping it easy to remove, and most importantly leaves no residue on your expensive Android smartphone.
Built of rugged plastic, the Clingo Mount stays cool in the summer sun but is sturdy enough to stay locked in position. The set up allows for multiple mounting options, to place your phone in just the right position. The suction design makes things easy to mount and remove, or re-position for multiple drivers.
The Clingo Universal Mount is an excellent way to keep your phone safe, and allows for distraction-free driving. Enjoy this video from Raul, and stay tuned for more from ShopAndroid.
- Filed under:
- Tags:
5343(forum posts)
