The Mobi Products Clip Pouch is a no-frills way to protect your Droid X. The pouch is made out of a soft nylon that's stitched together and fits the biggest of Android smartphones. There's a Velcro latch on the front that keeps the phone securely inside.
The rear of the phone sports a belt loop and plastic clip, so you can attach it to a backpack, purse or bag. Inside the case is a small pocket that's just big enough for a full-size SD card or a bit of loose change.
If you face the phone toward the rear of the pouch, you'll have access to the 3.5mm headphone jack (so you can listen to music while it's in the case), the power button and the volume buttons.
All in all, it's a very basic pouch that does its job well without adding much bulk to the phone. The Mobi Products Clip Pouch for the Droid X is available for $9.95 from the Android Central Store. Check out more pics after the break.
- Related devices:
- Filed under:
- Tags:
2438(forum posts)
