If the outside of your home is in desperate need of some TLC, one critical tool you'll need to get things back in shape is a pressure washer, and today Woot is offering the Earthwise 13 Amp 2000 PSI pressure washer for just $129.99. Now at a new low price, this deal saves you around $80 off its current cost at Amazon, and it has actually sold for as much $240 this year. This deal is only available until the day is out, though, so don't miss it. Shipping is free with Amazon Prime.
Home essentials
Earthwise Pressure Washer
Ever used a pressure washer? They're a lot of fun. And you can clean years of grime from your home or driveway.
$129.99 $213.00 $83 off
Earthwise PW20004 2000 PSI 1.2GPM 13-Amp Electric Pressure Washer
Equipped with a powerful 13 amp motor, this electric pressure washer is capable of generating up to 2000 PSI at 1.2 gallons per minute to blast away dirt, grime, and other unsightly marks you may find on the outside of your home, on your driveway, or out on the patio. It has a built-in detergent tank and comes with 4 individual quick connect spray tips — 0 degrees, 25 degrees, Turbo, and Soap — so you can switch easily depending on the task at hand. It's maneuverable thanks to its rear wheels and its 35-foot reinforced hose and 35-foot power cord mean you can move around with ease.
We may earn a commission for purchases using our links. Learn more.
