If you regularly plug numerous things into your laptop or find yourself reaching behind your desktop PC to find a USB port, you need something like the Dodocool 4-Port USB 3.0 Hub to make it easier. You can snag it for half price when you enter code UODANMAD during checkout. That code drops it down to just $7.49 making it a no-brainer buy.
Plug in
If you have limited I/O on your laptop or want to add some easy-access USB ports to your PC tower or iMac, this half price USB hub is for you. Just be sure to enter the below code to get the discount.
$7.49 $14.99 $8 off
With coupon: UODANMAD
The 4-port hub gives you easy access to 4 USB 3.0 connectors for plugging in your flash drives, external hard drives, camera, keyboard, mouse, and whatever else you may need to hook up. It works great with Windows or macOS and is plug-and-play so requires literally no setting up. You can transfer data at up to 5 Gbps and the ports are also backwards compatible with USB 2.0 if you're plugging in older tech. It has a 3-foot cable and is pretty compact so can slip easily into your laptop bag if you need to take it on the go.
Existing owners rate this hub very highly with an average score of 4.9 out of 5 stars.
We may earn a commission for purchases using our links. Learn more.
