Battery life is something that has improved big time in smartphones over the recent years, but if you're someone who travels a lot or just likes to consume a ton of media, it can still be a concern. This year, Motorola released three models in its G7 series, and right now you can pick up the long-lasting Moto G7 Power for just $179.99 at Amazon, which is a savings of $70. This brings it down to its lowest price to date, and if battery life is a concern for you this is definitely the phone to get.
Battery for days
Moto G7 Power
The G7 Power is rated to provide up to 60 hours of usage time per charge, which should easily power you through days of using your phone without a worry. It has a 6.2-inch display, a 12MP camera, and more.
$179.99 $249.99 $70 off
Thanks to its 5000mAh battery, it's rated to provide up to 60 hours of power per charge, which is enough to get you through two and a half days without needing to put it back on a charger. It also comes equipped with a 6.2-inch display, a 12MP camera, 3GB of RAM, and 32GB of internal storage. On the back, there's a fingerprint reader to make securing your phone a bit easier as well.
Not sure if the Moto G7 Power is the phone for you? Check out this handy comparison now and then compare the specs to the rest of the G7 lineup. Be sure to grab one now, before the discount is gone!
We may earn a commission for purchases using our links. Learn more.
