Take the best portable Wi-Fi hotspot with you on your summer holiday
Stay connected to the internet anywhere you go.
Packing your bags for that upcoming summer vacation? Add one of these excellent portable Wi-Fi hotspot devices to your list. Connecting to public Wi-Fi networks in hotels, cafes, and restaurants comes with a myriad of risks. Not to mention, using your phone to hotspot your other devices drains battery really fast. A portable Wi-Fi hotspot fixes all these issues and more!
These portable gadgets usually have built-in batteries so you can power them anywhere, and they tend to accept universal SIM cards so they can latch on to 4G or 5G networks anywhere in the world. These devices are also designed to handle multiple simultaneous connections without overheating or choking the bandwidth.
The gold star of portable Wi-Fi hotspot devices is the Netgear Nighthawk M7 as it supports the fastest 5G speeds and supports Wi-Fi 7. Not everyone needs a $500 mobile hotspot though, so we've also lined up more affordable options for casual users.
Invest in the portable Wi-Fi hotspot for your travel needs
Best overall
The exceedingly pricey Netgear Nighthawk M7 is the best portable Wi-Fi hotspot around. Equipped with 5G mmWave support, this hotspot has 3.6 Gbps dual-band Wi-Fi 7 support, a 3,850mAh battery, and both Ethernet and USB-C connectivity.
Best multipurpose
This isn't just a cheap under-$40 mobile hotspot. The TP-Link Roam 6 AX1500 is a versatile wireless travel router with a router mode, a hotspot mode, and an AP/RE client mode. Connect up to 60 devices and enjoy 1.5 Gbps dual band Wi-Fi 6 on the go.
Best value
While Netgear's flagship model is achingly expensive, the Nighthawk M1 has a more amicable asking price, albeit with watered-down specs. You get AT&T and T-Mobile support, download speeds of up to 1 Gbps, and 4G LTE connectivity.
Best for international use
The Huawei 4G Mobile WiFi 5 (E5586-326) is a 4G LTE hotspot device that is quite affordably priced. It doesn't work in the U.S., Canada, and neighboring regions, so it's better fitted for regions like Africa, Asia, Europe, and the Middle East.
Pick the right portable Wi-Fi hotspot to match your needs on the go
Which portable Wi-Fi hotspot device is right for you depends entirely on your individual needs. Not everyone requires the fastest Wi-Fi 6 or Wi-Fi 7 speeds with 5G mmWave support. Most of us only need portable mobile hotspot devices for streaming videos and music, light work on the go, or navigational purposes.
That being said, anyone who wants the cream of the crop should purchase the Netgear Nighthawk M7, as long as money isn't an object. It has everything a user could want from a portable Wi-Fi hotspot: lightning-fast 5G mmWave speeds, Wi-Fi 7 support, speeds up to 3.6 Gbps, both Ethernet and USB-C connectivity, and a generous 3,850mAh battery that should last you 10 hours. It's the complete package, ships unlocked, and supports both Verizon and AT&T.
There are several significantly cheaper alternatives available if you're not prepared to spend that much cash on a mobile hotspot. The Franklin A50 is a really cheap option that works on AT&T. You can pay as little as $5 per month for this baby. If you want something unlocked, Netgear's affordable TP-Link Roam 6 AX1500 Portable Wi-Fi 6 Travel Router is a solid pick that offers a great mix of specs for a low price.
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
