Zens wireless speaker and charger
Zens' new 4,500mAh Power Bank chargers bring the juice and the tunes
We're big fans of the Zens Qi wireless chargers around these parts, and we're really digging the news Zens sent us today.
They have two 4,500mAh Qi wireless Power Banks in the works to dole out all sorts of electrons to keep your compatible device going and going. The standard Power Bank charges via USB, and the huge capacity means you're always close to power when you need a top off or when that battery dips into the red. Since it uses the Qi standard, there are hundreds of different devices that are compatible. Set the Power Bank down, drop your phone or tablet up top, and the magic flows.
Their next product takes everything above, and adds a wireless speaker to the mix. Using Bluetooth, the two 5-inch speakers should deliver a lot of sound, even when you're charging your Qi-compatible device up. The ZENS Qi Wireless Portable Audio Speaker also uses NFC to tap and pair with phones or tablets automatically.
The Power Bank will retail for about € 69.99, and should be in stores by March 30. The Qi Wireless Portable Audio Speaker will retail for € 99.99 and will also be available March 30. The units are a little pricey, but as we've all experienced, you get what you pay for sometimes. We'll be checking them out as soon as we can.
