unrevoked
The Droid Incredible was a tough nut to crack, but cracked it was, though the method for rooting was a bit, shall we say, difficult. But the Unrevoked team has updated its one-click method for the Dinc, and it's a new day in America, folks. Fear not, and get your root on. [Unrevoked via Twitter] Thanks to everyone, and we mean everyone, who sent this in.
There are 63 comments
rugbyua9 says:
yayyyyy...glad my replacement came in yesterday!
johnnycat#ac says:
ok i have rooted how do i take advantage of it ? can i unlock 720p ect or not
csteenbock says:
ive been waiting so long for this! i will attempt this after i get off work.
any idea on how long the whole process takes? im pumped
jason821 says:
If i do this to my Dinc, then i get a replacement on monday, will i be able to remove this so they dont know it was rooted?
beatle says:
Even the "old" method can be done in 10 minutes if you're quick. I bet this only takes 5.
skunis1 says:
The site appears to be down on my computer here at work. I do not see the Incredible on the homepage and none of the links from each phone do anything.
Kedar says:
This takes literally like 5-10 minutes if you do it correctly. I just did it on my Evo.
Just install drivers (there's a file that comes with the download saying how) and run the .exe file.
Awesome stuff.
crxssi says:
.exe files don't run in Linux nor MacOS. So it might not be quite that way.
Kerensky97 says:
If you're really a Linux user you know that the Linux way is to do the programming yourself. It's called open source, program and compile the code and you're done.
JoshUng says:
Hey, they're just like Best Buy, with the Arai being as big as the Evo :)
DreamSTi says:
I cant seem to find a good link to the Incredible root for this. Ultra mega fucking fail.
kentoe says:
Here's the link for the reflash+root, the homepage is temporarily down for some reason/broken.
http://www.unrevoked.com/recovery/
jason821 says:
Does anyone know if this can be undone? I'm getting a replacement on Monday and I don't want to do this if it can't be undone.
arundc says:
You can't wait 3 days to perform the root on the replacement? Geez man :)
kentoe says:
Yes, it will eventually (if not already) be able to be undone. A later RUU will be available to return back to stock however the newer RUU may prevent re-rooting.
sgitlin25 says:
I'm a noob with rooting...how do i get Froyo on my Inc after Rooting?
kentoe says:
http://forum.xda-developers.com/showthread.php?t=722481
Look there for more information (it's not official froyo yet)
sgitlin25 says:
thanks
jason821 says:
I must have had too much to drink last night. I can't figure this out....
Kedar says:
Download the .zip file that comes from the download.
Run the zip file it should ask where to extract it... Choose whatever folder.
Open the .htm file in the list of files that extracted.
It gives you directions on how to install the drivers.
Once the drivers are installed... just connect the phone to your computer and select charge only for now. Run the reflash executible file...
It should reboot your phone into recovery mode or whatever. Basically use the volume down button to select HBOOT USB and press the power button.
It'll do everything else on its own.
Then once the unrevoked 3 program says "Done"... and just press power again and you'll be rooted.
That's basically it. I even made it seem a bit more complicated than it really is.
The unrevoked3 program should already lead you through whatever I said, but I just reiterated it.
jason821 says:
Thanks! How long should this take?
Jeepzor says:
Yea mine still doesn't work. I have done everything it says as far as using the drivers. it even says android bootloader. The unrevoked application reboots my phone into hboot and then says wait for reboot. The phone then restarts and says "HTC INCREDIBLE" Stays there for a min and then the unrevoked app says pushing recovery do not touch phone but about 2 seconds later my phone goes through its startup sequence even as the unrevoked app is trying to talk to it.
jason821 says:
Mine is at "waiting for system to settle" about 5 minutes now
tsakosh says:
same exact thing here... except mine doesn't get to pushing recovery, still waiting to reboot even though my phone already rebooted...
did you get yours??
L Wa says:
What does this do for your phone? sorry for my ignorance!
Kedar says:
It half-roots your phone.
It gives you superuser permissions.
With superuser permissions, you can do wifi tethering, which is a big deal for MANY people.
Then you can also backup your apps using Titanium Backup.
Wifi tethering, as you should know, lets you use your phone's internet connetion on other devices like your laptop/netbook/ipod touch/DSi/etc.
..not that many
jason821 says:
Anyone successful yet?
cuong#wp says:
Supposedly the OTA update is coming today that seems to include the same goodies as the root. Should I just wait for the OTA or will root give me something better/different?
If I root, will I lose the ability to receive the OTA update?
budwizer says:
Isn't this kind of old news? This has been out since the last week of June.
jason821 says:
Done! Uninstalled HTC Sync and all drivers that came with......YAY!!!
dtisme says:
Im a noob. Does this wipe the phone?
izzyncade says:
I tried this, all of it. I installed the drivers it pointed me to, I followed every step as it is said to, and I cannot get this phone rooted... oh well, I guess I will just not do it and deal with that ever annoying city ID.... oh the horror...
hoosiercub says:
This was much easier on my Mac and or Linux where there was no USB driver tinkering to be done. Rooted a few days ago, was wondering when you guys were going to post this as I thought this was kind of a big deal. Now if only we can get a stable version of CM6 for the DINC that allows the camera/gps/wifi and everything to work, I'll start ROM flashing :)
Kipp says:
AMAZING! This took all of 2 min if that it did everything all I had to do was plug the phone in and done it did the rest! Im rooted and ready to rock!
Mac OS X
HTC Inc
marrerom77 says:
downloaded unrevoked but it says waiting for device,plug phone in now and enable usb debugging. i plug it in but nothing happens HTC EVO Mac OSX can someone help please
tcox8 says:
you have to enable the usb debugging. You can do that by doing the following.
from your phone:
Settings -> Applications -> Development -> USB debugging (make sure it's checked)
marrerom77 says:
thank you
Markimus says:
Uber YES I am now rooted on my DI and boy do I love it. Droid x users have wifi tether but they need to pay for it suckers!!!!!!
cuong#wp says:
Well, apparently it worked. Sort of. The only thing I noticed is the SU icon on my phone but it does nothing with regards to WiFi tethering. Did I miss something?
cuong#wp says:
Also, no 720p recording. What exactly did I not install?
tucker301 says:
You gave yourself root permissions and you installed the ClockworkMod Recovery Image, which allows you to fully backup your phone to your SD card.
After that, you can visit http://code.google.com/p/android-wifi-tether/wiki/Setup_HTC_Desire_Incre... and get started on setting up wifi tethering, if you wish.
Or you can start researching alternative ROMs for your phone.
marrerom77 says:
Nice my Evo was rooted in five mins,thankx for the help
tucker301 says:
1. You must enable USB debugging on your phone.
2. Windows users must install the included device drivers.
3. This does does not automatically give you 720P camera or Wifi tethering.
Wifi thethering requires a little more work, but is very doable.
Instructions: http://code.google.com/p/android-wifi-tether/wiki/Setup_HTC_Desire_Incre...
4. BIG thanks to the developers. I like your sense of humor.
http://imgur.com/vR7Vi.jpg
tsakosh says:
all the folks talkin about rooting evos aren't helping us who are trying to root are incredibles.... it's an incredible thread isn't it???? all you're doing is confusing me.
with that being said, i've got the drivers installed, but what next? my phone is still sitting here in recovery mode tethered to the computer.... the next step on the directions just says run the unrevoked executable file, enable usb debugging on my phone and then tether it...
do i need to reboot my phone?
do i leave it tethered and then run the evo3 file?
help, please???
tucker301 says:
Reboot the phone into its standard operating configuration. Just like you're going to use it. Then run the exe
marrerom77 says:
Evo!!!!
tsakosh says:
reboot while it's still tethered???
tucker301 says:
Leave the USB cable connected.
tsakosh says:
idk, it's "pushing flasher" for like a million years now.., is it cuz i'm running windows XP and not vista or 7????
tucker301 says:
Did the phone drivers install correctly?
You should have "android phone" > "android bootloader interface" under device manager.
http://imgur.com/dmIuG.png
tucker301 says:
Who has a good lead on ROM's for the Incredible?
clabbin says:
So is this the complete root that allows me to flash custom roms or is it just the same as the half root that I did a few weeks ago
tucker301 says:
As I read it, you can flash a custom recovery image in .img format, but not a .zip ROM.
From the More Information page:
How do I use a custom recovery image instead of the packaged ClockworkMod?
You will need to choose a .img file, which is a binary file suitable for flashing. A .zip file will not work and may render your recovery partition inaccessible until you run unrevoked3 with an appropriate image.
clabbin says:
Huh.... i'll have to try it out. Do I need to unroot my phone from before? Or can I just go ahead with this?
tucker301 says:
No idea. But I wouldn't unroot a phone that's already been rooted.
Thus far, I cannot find a single IMG to flash to my newly unlocked Incredible.
Meanwhile, ROM's are aplenty.
sportfan1969 says:
So, here goes,
9:43 AM - Downloaded & Installed UNREVOKED3
9:44 AM - Downloaded & Installed Android USB driver
9:45 AM - Connected Incredible to PC while UNREVOKED3 running
9:49 AM - (after "waiting a couple extra seconds cause windows sucks" I Have ROOT! WOOT WOOT!
Soo...Now that I have ROOT what mayhem can I get into?
Thanks to the Unrevoked3 Team for making this "Painless".
tucker301 says:
I just found this comprehensive guide to rooting the phone and a host of things you can do with it afterward, including trying out new ROM's!
Great stuff!
http://www.jonamerica.com/technology/howto-root-the-htc-droid-incredible/
JiggyJames54 says:
I am trying to root but I am stuck. Under other devices in device manager, I have a question mark with an exclamation point next to android 1.0. When I right click I get the option to update driver but when I click it, I get the update hardware wizard. I am running Windows XP. Can anyone help?
followed all directions and all drivers are installed, (don't recall phone rebooting) then set to debuging mode and evo3 has been saying "pushing recovery image" for about 20 mins. now ??? any ideas
D1RTD1VER1 says:
i followed the 10 min. root video on this site and youtube and had some problems i don't know anything about to even begin to fix. i downloaded sdk and put it in the c:\ drive, opened prompt and followed the inst. and got the device not found. followed the inst. through the rocovery mode selection on the handset and after that the man explains two ways to get the desired result; first typing the up arrow and enter on adb shell, and second (if that didn't work) typing loop.bat. neither do anything for me and i hit both like a hundred times. they just say the path not found or adb isn't recognized as and internal or external command (something or other). I tried to download root explorer and got everything working but then is said my phone needed to be rooted. also tried to do it tethered through cmd prompt and the c drive and adb push and it won't push my custom boot thingy. that is all i want it to have a cool boot logo or startup whatever you call it. PLEASE help if ya don't mind thanks for your time
GOD I am so frustrated it's not even funny. I followed ALL the instructions on the unrevoked website for my incredible. I have all drivers installed correctly. Everything is as it should be. USB debugging is on. Sd card is out. I have my incredible plugged into the usb and on charge only, with debugging. I run the reflash.exe and the unrevoked3 screen comes up and says waiting on my device.
for some reason it isnt recognizing it.
If one more person tells me to turn debugging on I'm going to shoot myself because damnit it is on!
Someone please tell me there's something I can do about this? I've been trying to sort out this problem for about 3 hours and frankly I'm pissed. Also I'm running off of windows XP if that matters.
