Pebble updated to 2.0.2
A quick heads up for you folks glancing at your Pebble smartwatch today with a bit of unease (it's OK to admit it) — there's a firmware update waiting for you. Pebble said the small point increase (we're up to 2.0.2 from 2.0.1) fixes an issue some folks had installing the firmware. So it's a firmware update to fix a firmware update. Anyhoo — head into your Pebble 2.0 app, then go to support, then go to "Check for updates." Then update. Done.
