Remember that controversial Motorola Droid 4 root method we talked about last week? You might have skimmed over the part where the method was presumed to work on just about any Motorola device, but it seems to be true -- the Motorola Droid XYBOARD (both versions) have been rooted using the method.
There's not a lot to actually do with your XYBOARD that needs root just yet, but we're sure all that will change soon now that an easy method is available. It looks simple enough -- install some drivers then run a batch file to root the tablet. You can find all the particulars and the needed files at the source link, and of course join the discussion in the forums if you hit a snag.
Source: Vulnfactory.org
4817(forum posts)
