Xperia Z3 Compact
Sony's upcoming Xperia Z3 Compact has leaked several times already, giving us a look at the design and specs of the device. Today's set of leaked images give us a closer look at the camera sensor at the back and various ports present on the device.
It looks like the Xperia Z3 Compact will retain the 1/2.3-inch 20.7MP Exmor RS sensor that first made its debut on the Xperia Z1. Images of the sides of the device reveal that the location of the ports are relatively unchanged, with the microSD card slot housing the microUSB charging port, both of which are covered, just like the previous models.
There is a magnetic connector on the left side of the device and an open 3.5mm audio jack at the top. From the images, we can see that the button layout is also unchanged from earlier models, which includes a circular power button in the middle with volume rockers and a dedicated camera shutter key on either side. The leak also reveals a few Xperia Z3 images, which highlight a similar design as its smaller variant.
Sony is set to unveil the Xperia Z3 and the Xperia Z3 Compact at the IFA next month. While we've seen many leaks of the device until now, there is still not a single image that offers a clear look at the front of the device, which is rumored to house a 4.6-inch 720p screen. We'll be live at Sony's event at the IFA, so make sure you stay tuned to Android Central for further coverage.
What do you guys make of the latest set of leaked images?
Source: XperiaBlog
