Seidio Innocase Rugged holster combo
The Seidio Innocase Rugged holster combo is a case for the Droid Incredible that would be more accurately described as a tank than as a case. The case itself has three separate layers: the Seidio Innocase II case goes around your phone first and is then itself encapsulated inside a thick rubber lining and a rigid plastic skeleton shell. This by itself would be a case worthy of respect, but Seidio has gone even farther by including a set of screen protectors and a holster to keep the entire thing strapped to your belt or waist.
The great thing about this case is that it can really be used as three separate cases. The Seidio Innocase II is a great thin case in its own right, and there is nothing preventing you from simply using it as your daily in-pocket case to keep the phone from getting scratches. Adding the rubber and stiff plastic layers creates a much more durable case, which would offer much better protection from drops. Using the holster makes sure your phone is within easy access on your hip and would be great for someone who needs quick and constant access to their phone. The screen in turned inward when held in the holster by a slide-locking clip, so you have no worries about your phone falling off the holster. Considering the versatility, this is a great buy for someone who may want a super rugged and durable case but is not sure they would want to carry their phone in it at all times.
Our very own Jerry Hildenbrand reviewed this very case for the Evo 4G and shot a great video showing you how to assemble this monster step-by-step. Check out his review for the video and check out more pictures of the Droid Incredible version past the break. The Seidio Innocase Rugged holster combo for the Verizon Droid Incredible will run you $49.99 in the Android Central Store.
Back of case with all layers
Back of Seidio Innocase II layer
Side view of the holster/clip
The components of the case
Front view
There are 13 comments. Add yours.
radgatt says:
For $50 it better protect everything! That's too much work but I could see why people would want it.
Slip85 says:
Sick Samus wallpaper, Kyle.
Kyle Gibb says:
If you check my old videos/reviews, you will see I have had it for quite some time ;)
Slip85 says:
I know. I felt like reiterating its sickness.
wipeout says:
I have the holster (no case) for my Evo and love it. - I had one for my Touch Pro before I got the Evo.
Curious, is that a tasker icon? Where'd that icon come from, I like it.
Kyle Gibb says:
Which icon?
wipeout says:
The gear-looking one in the active notifications section (top left).
Kyle Gibb says:
http://www.androidcentral.com/android-quick-app-quick-settings-0
wipeout says:
Aha, thanks!
md17 says:
This case scratched the sides of my phone so bad
makya53 says:
This is by far the best case solution ever! I liked it so much that I ditched my 3500 battery and switch twice a day. It's the best of both world I'm in construction and it switches in seconds.
stoneworrior says:
This is what I have had my evo in for six months. The inner case started to fall apart from frequent battery changes. I went online yesterday and filled out a RMA warranty request. They approved it within two hours and I sent the case out today. Honest company that stands behind their products.
Yadao says:
Been using this case since September. It's been great, it's saved my phone a few times. The rubber and plastic outer shells are showing some wear, but still function perfectly. I love how it covers the camera and ports. It keeps the heavy dust at work out which ruined my old phone.
