If you're looking to protect your Samsung Galaxy Nexus with something flexible and strong, but want to travel in style, the Cruzerlite Androidified A2 TPU Case is definitely the case you seek.
Made out of that signature orange goo Phil was good enough to coat his hand with (and subsequently get smashed with a rubber mallet), these Cruzerlite cases offer exceptional shock absorption while still keeping the overall size of the phone and case small.
Holes are cut and placed appropriately, giving you access to all of your buttons and necessary ports (including the inductive charging port). Despite the thinness of the case, I'm not positive any docks will be able to reach the inductive charging area, but do know that it's not covered.
The edges of the case add a small buffer zone, keeping your all-important touch screen lifted up, should you decide to place it with the screen facing down. Better yet, this case fits perfectly on phones using the standard battery or the official Samsung 2100 mAh extended battery, too, so you can get your extra charge on all while keeping your phone nice and secure.
If you're looking for a solid case to keep your phone intact and want to show off your love and support of Android, this case should certainly warrant some consideration. To top it off, it comes in 11 colors, too!
- Related devices:
- Filed under:
- Tags:
30(forum posts)
