The ZealSound dual 10W wireless charging pad drops to $13.99 on Amazon thanks to a promotion taking 60% off the price and a 5% off on-page coupon you can either clip in your shopping cart after you add it using the above link or clip here on the product page.
Set it and forget it
Combine the 60% off promo link with a 5% off on-page coupon to get this wireless charging pad down to one of its lowest prices ever.
$13.99 $40.00 $26 off
This is a 2-in-1 charger that can hold your Qi-enabled wireless charging smartphones and the Apple Watch (Series 1/2/3 but not 4). The pad even comes with its own USB 3.0 adapter and an advanced chipset. If you use a phone on your case, make sure it's not thicker than 4mm and you should be able to charge without having to remove it. The advanced safety features include temperature control, surge protection, short-circuit prevention, and more. You'll get 10W for Samsung Galaxy phones, 7.5W for the iPhone 8 and above, and 5W for other Qi-compatible devices.
More Black Friday deals:
We may earn a commission for purchases using our links. Learn more.
