How many disposable lighters have you gone through in your life so far? A few bucks here and there adds up to a lot of money spent after awhile, when instead you could pick up something like Tacklife's ELY04 Electric Arc Lighter that can last for years to come. It's normally priced just under $11 on average, and using code ICZA9UGG during checkout at Amazon can even drop its price to $4.48 for a limited time.
Boogie Woogie Woogie
Tacklife ELY04 Electric Arc Lighter
This windproof electric arc lighter lets you recharge its integrated battery via USB, offering over 300 sparks after a single charge. You'll just need to enter the code below to snag this low price.
$4.48 $10.59 $6 off
Tacklife T8 800A Peak 18000mAh car jump starter with LCD display and quick charger
Works on most cars, SUVs, trucks, and more. Can jump start up to 30 times on a single charge. Charge mobile devices with two USB ports and an 18000mAh capacity. Even has Quick Charge and a built-in LED flashlight. Covered by a two-year warranty.
Tacklife Power Station 300W
Getting off the grid for a while is easier with Tacklife's new Autumn Exclusive Power Station. This 300w portable solar generator drops nearly $100 in price when you use the following promo code during checkout.
Tacklife 1200A Car Jump Starter (KP120)
Packing for your summer road trip won't be complete without ensuring you can jump-start your vehicle's battery in a pinch. This 1200A peak model is suitable for up to 8L gas or 6L diesel engines. Use the 5% on-page coupon and the below code to save.
Tacklife 2-in-1 Magnetic Wristband and Waistband
Keep nails, drill bits, screws, and other parts readily available using this handy wristband. It's now nearly 50% off at Amazon, no coupon required.
Tacklife 2600mAh USB-rechargeable electric arc lighter
The lighter has a 2600mAh battery that's USB rechargeable. No gas. No mess. No smell. Just fire. Burn baby, burn. It's wind and rain proof and has a flexible neck for hard to reach spots. Comes with a lifetime warranty.
This electric lighter is equipped with a built-in USB rechargeable battery that allows it to spark up more than 300 times on a single charge. When it goes dead, simply plug it back in to charge and you'll be able to continue re-using it soon after. It can be powered using the USB port on your computer, a USB wall charger, or even a portable power bank.
Fitted with a 4-inch 360-degree rotatable neck, this lighter was designed to keep the spark away from your hand to reduce the risk of burns and other accidents. Plus, it's windproof, splashproof, and comes with a lifetime warranty from Tacklife.
We may earn a commission for purchases using our links. Learn more.
