I've said it before and I'll say it again: every single car should have a portable tire inflator in it. You never know when you'll need it most, and the last thing you want is to be stranded with a flat somewhere. Best case scenario, it takes a lot of time and effort to fix the issue. Worst case scenario, the zombies get you. Prevent both by picking up the Gooloo 12V Portable Air Compressor for $8 today at Amazon when you enter code H5YOICAD during checkout. That's over half off the usual $20 price tag, and the reviews aren't too shabby either.
Better Save Than Sorry
This is super easy to use and an absolute no-brainer at this price point.
$8 $20 $12 Off
With coupon: H5YOICAD
This 12V inflator is super simple to use. Plug it in to your vehicle's cigarette outlet, attach the hose to the thing you need to inflate, and turn it on. The built-in pressure gauge ensures that you reach the correct levels, and it can handle up to 300 PSI so you'll be covered for basically every situation. There are a few different nozzle adapters included for the perfect fit, too. Everything stores neatly inside the compressor itself when you're finished.
We may earn a commission for purchases using our links. Learn more.
