If you're adventuring around the world, it's smart to pack light, which is where multi-use items can come in handy. Take, for example, this Bestek Universal Travel Adapter and Voltage Converter. Usually it costs $35.99, but you can snag it for $20.15 today when you clip the 5% off on-page coupon and apply code FFEL9UIB at Amazon. That price drop is the best we've seen.
Go Farther
Keep your stuff charged, no matter where you're at. The voltage conversion means you can use things like electric toothbrushes or curling irons, too. Make sure you clip the on-page coupon and enter the code below during checkout.
$20.15 $35.99 $16 Off
With coupon: FFEL9UIB
This deal is unusual because while we've seen plenty of discounts on travel adapters, typically they don't also convert voltage. This particular model works in over 150 countries. Not only will it help you use your tech thanks to its AC and USB power, but it can also assist you in voltage conversion so you can use things like hair straighteners, curling irons, or other appliances below 150W. It doesn't pack enough power for items like a hair dryer, but thankfully most hotels will have you covered on that front. Your tech will be protected thanks to the built-in safeguards against overcharging, overheating, and the like. Should anything happen, the manufacturer backs the adapter with a two-year warranty.
We may earn a commission for purchases using our links. Learn more.
