We've gathered all of the day's best deals on tech and more below to save you having to hunt them down alone. Most are limited in time, so make sure you don't miss out.
LG 65-inch 4K Smart TV - $699.99 (from $800)
The LG TV has a ton of smart features. It has Amazon Alexa and Google Assistant voice assistants built right into it, and they both work well with LG's ThinQ AI, which can listen, think, and answer your questions. The TV is also designed to work with Apple HomeKit, so you can use the Home app and Siri to control your TV or your larger smart home. Use any Apple device, including an Apple Watch or iPhone, to control your TV. Use any of the three voice assistants, along with LG's advanced intelligence, to search for your favorite shows, keep an eye on security camera feeds, dim the lights, and much more.
NanoCells
LG 65SM8600PUA Nano 8 series 65-inch Alexa 4K smart TV
Matches Best Buy as a deal-of-the-day. Has Alexa and Google Assistant built in. Supports Dolby Vision and Dolby Atmos for advanced images and sound. Uses NanoCell for vibrant colors. Also has AirPlay 2 so you can stream from Apple devices.
$699.99 $800.00 $100 off
LG G8 ThinQ Smartphone (Unlocked, 128GB)
Now at $450 off its regular cost, this device becomes a much more enticing offer featuring a Snapdragon 855 Octa-Core processor, 6GB of RAM, and dual rear cameras. The only catch is that the deal ends later tonight, so place your order soon!
LG 50-inch 4K UHD Smart LED HDR TV (50UN7300)
Target has LG's 50-inch 4K UHD LED Smart TV on sale today for just $350, saving you $50 off its regular cost. This is a Cyber Deals week offer that may not last much longer, so don't wait!
LG 27UK850-W 27-inch 4K USB-C monitor
Combine 4K resolution with an IPS panel and HDR10 for superb image quality and color accuracy. Includes a response time of 5ms and a refresh rate of 60Hz. Has AMD FreeSync tech to reduce screen tearing. Has USB-C, USB-A, DisplayPort, and HDMI.
LG 27UL600-W 27-inch 4K FreeSync monitor
LG's 27-inch screen includes VESA certified DisplayHDR 400 for awesome image quality. It has a 5 ms response time and 60Hz refresh rate. Includes AMD FreeSync tech, two HDMI ports, and one DisplayPort. IPS panel has 178-degree viewing angles.
LG 34GP83A-B 34-inch Ultragear curved Nano IPS gaming monitor
The UltraWide display has a resolution of 3440 x 1440 and uses LG's Nano IPS tech for color accuracy. Includes a 1ms response time and a 144Hz refresh rate. Has native FreeSync but is G-Sync compatible. Even supports VESA DisplayHDR 400.
Razer Firefly Chroma mousepad - $34.99 (from $50)
The Firefly mousepad uses a hard, micro-textured finish that helps with both control and speed. The precise, consistant surface gives you great precision and complete control. Whatever mouse you use with whatever settings it has will only improve when used in conjunction with the Firefly mousepad.
Precision
Razer Firefly Chroma gaming mousepad
Uses a hard, micro-textured finish to help with both control and speed. The surface gives you precise and complete control regardless of your mouse or your sensitivity settings. You can customize the lighting underneath with 16.8 million options.
$34.99 $52.00 $17 off
Razer BlackShark V2 Pro wireless gaming headset
The headset has THX 7.1 Surround Sound, which creates audio realism for in-game immersion. Uses TriForce Titanium 50mm high-end drivers and has cooling gel-infused cushions for comfort and to prevent overheating. Detachable cardioid mic.
Razer Opus active noise-cancelling Bluetooth headphones
The ANC in these headphones can detect and nullify incoming noise. They have a 25-hour battery life and are engineered for comfort that entire time with leatherette memory foam ear cushions and a well-balanced weight. Can go wired to save battery.
Razer BlackWidow Chroma RGB Green switches mechanical gaming keyboard
Has Razer's signature Green mechanical switches with a clicky sound, 50G of actuation force, and high accuracy. Razer Chroma is RGB lighting that syncs with other Razer gear and third party stuff. Hypershift gives you programmable macros.
Razer Basilisk X Hyperspeed wireless optical gaming mouse
Uses Razer's HyperSpeed tech for a wireless experience as nearly as responsive as wired. Includes Bluetooth and a 16,000 DPI Sensor that can be adjusted. Has on-board storage so you can save programmable button settings. Works with Windows and Mac.
Razer Kraken Tournament Edition THX 7.1 Surround Sound gaming headset
Audio realism for in-game immersion thanks to surround sound directional clues and accurate spatial audio. Has custom 50mm drivers, gel-infused cushions for long-term comfort, noise-cancelling mics for clear communication, and more.
Echo Show 5 2-pack - $89.99 (from $120)
Grab two Amazon Echo Show 5 smart displays and use the code SHOW52PK to get them for $89.99 total. They would cost you $120 without that deal, so you're basically getting a second device for 50% off. Whether you want two smart video displays in your home or just want to give one away as a gift for someone you missed at Christmas, this is a great deal that saves you a good chunk of money.
Video
Amazon Echo Show 5 double trouble
This is a compact 5.5-inch smart display with Alexa built in. Manage your calendar, make to-do lists, get weather updates, or follow along with recipes on the screen. Use your voice to control your devices and view feeds on the display.
$89.99 $120.00 $30 off
Amazon Dash Smart Shelf
Dash Smart Shelf is a smart scale that can automatically re-order pantry staples, pet products, office supplies, etc, for you or notify you when supplies are running low. With Subscribe & Save, you can also get a discount on re-ordered items.
Amazon Kids+ Family Plan
Kids+ gives your child access to kid-friendly shows and movies, eBooks, educational games and apps, and even Audible books! It's one of the most affordable services out there, and right now you can score a year-long family plan for just $20.
Amazon Echo Flex + Sengled Smart Bulb
This tiny smart speaker plugs right into an AC outlet in your home so you can speak with Alexa, stream music, control compatible smart home devices using only your voice, and more. It's $15 off and you get a free smart bulb worth $10 for free.
Fire TV Stick with 50% off Hulu
Amazon is offering a special 50% discount on Hulu for six months when you purchase a Fire TV Stick for a limited time! The Fire TV Stick devices are all on sale for the holidays right now, too.
Free $5 Amazon credit for watching Aflac advertisement video
Watch 30-second Aflac advertisement. Verify captcha at the end of the video. Get a $5 promo credit attached to your Amazon account. Easy. Offer ends Jan. 15, 2021. Promo credit works on anything shipped and sold by Amazon but expires Feb. 15, 2021.
Oria 126-in-1 Precision Screwdriver Set - $19.49 (from $30)
Oria's screwdriver set, which is discounted to $19.49 using the code WXYXPTXCG, comes with 112 different kinds of screwdriver bits made of chrome-vanadium steel, all of which have been carefully selected to help fix popular devices, eyeglasses, and more. The kit also includes accessories such as a screwdriver handle, an opening tool, tweezers, and a SIM card tool. It even comes with a flexible extension shaft to help you work in tight, narrow spaces. Oria includes a nylon bag with this kit's purchase to keep everything carefully organized while it's stored away.
DIY All Day
This portable screwdriver set comes with over 110 different kinds of screwdriver bits so you can always be ready to work on phones, game consoles, computers, or even eyeglasses. Use the following code to save $11 at Amazon.
$19.49 $29.99 $11 off
Oria 60-in-1 Precision Screwdriver magnetic driver kit
Includes 56 precision specialty bits, one magnetized driver handle, a flexible extension, and a driver adapter. Bits made of CRV steel, which means they're hard, durable, and high performance. Repair screws in deep positions and narrow spots.
Oria 60-in-1 Precision Screwdriver Set
This precision screwdriver set comes with 56 varied bits that were carefully selected to help repair popular electronics, eyeglasses, and more. You'll just need to enter the following code during checkout to snag this low price.
This toolkit is great for completing repairs on your electronics as well as doing tasks around the house, so don't miss out on this deal offering 20% off its average price using the coupon code below.
ORIA 25-in-1 Long Screwdriver Kit
From tablets and phones to eyeglasses, cameras, and more, this simple screwdriver kit can help you fix your things rather than replace them or spend all your money at a repair shop. Just make sure to enter the code below to snag the best price on it.
This precision screwdriver set comes with 56 varied bits that were carefully selected to help repair popular electronics, eyeglasses, and more. You'll just need to enter the code below to snag this low price.
Samsung 50-inch 4K Smart TV - $296.99 (from $380)
Not only is this TV on sale right now, but you can also get a free Google Nest Mini smart speaker with the purchase. That's another $50 in savings. Samsung's 50-inch Ultra HD Smart LED TV features an effective refresh rate of 120Hz, two HDMI ports, a USB port, and Dolby Digital Plus audio. It also supports HDR10, HDR10+, and HLG HDR formats and is equipped with Motion Rate 120. The best feature of all, however, is its built-in Wi-Fi that allows you to download apps straight to the TV. From there, you'll be able to access and stream services like Netflix, Hulu, Amazon Prime Video, YouTube, and other top channels. It's even able to access new services like Disney+.
Binge-worthy Bargain
Samsung 50-inch 4K UHD Smart LED TV (NU6900 Series)
This 4K UHD HDR Smart TV offers integrated access to Netflix, Amazon Prime Video, Hulu, and tons of other popular streaming services. Plus, Best Buy is including a free Google Nest Mini with its purchase automatically!
$296.99 $379.99 $83 off
Eufy Security 2K video doorbell - $105.99 (from $160)
Thanks to a limited-time sale at Amazon, Eufy's 2K Video Doorbell is now down to just $105.99 when you clip its on-page coupon and use promo code WRECUTDB2 during checkout. That saves you over $50 off its usual cost of $160.
Eufy's 2K video doorbell has 2560 x 1920 resolution with HDR and distortion correction, which ensures quality video recordings. With two-way audio, you can hear and speak directly to anyone who approaches your door. The camera uses advanced AI technology and algorithms to detect body shapes and face patterns. The system is designed to be weather-resistant too, so you don't have to worry about it being outdoors and exposed to the elements.
Ding Dong Deal
Eufy Security Wi-Fi 2K video doorbell
Eufy's 2K Video Doorbell lets you speak to anyone who approaches your front door using an app on your phone. You'll be able to see them too. Clip the on-page coupon and use the following code during checkout to save over $50 instantly.
$105.99 $159.99 $54 off
Eufy Security 1080p Wi-Fi video doorbell with free chime
The 1080p-grade resolution combines with advanced HDR and Distortion Correction tech for crisp, clear video. Use two-way audio to speak with visitors. Has AI that can detect a human body versus say a dog or car. Get notifications that matter.
Eufy Security 2K indoor 2-camera kit
The cameras can detect motion and use on-board AI to determine whether it's a human or a pet. View it all in 2K resolution. The cameras also feature two-way audio, and night vision. Connects to Apple HomeKit, Google Assistant, and Amazon Alexa.
Eufy Security EufyCam 2C Pro 2-camera wireless home security kit
Watch video in 2K resolution. Each camera has a battery life that lasts up to 180 days. The cameras also have night vision and human detection technology that can detect body shapes and face patterns. IP67 rated for outdoor use.
Eufy C1 Bluetooth Smart Scale
Eufy's Smart Scale can track up to 16 users at once and can tell you much more about your body's health than most scales. It even connects with an app on your phone for a better look at your stats. Clip the on-page coupon for $11 off.
Eufy Security 5-piece Home Alarm Kit Smart Security System
Eufy's kit comes with a HomeBase, keypad, motion sensor, and two entry sensors. It can cover doors and windows, give you instant alerts, and arm or disarm in seconds. You can add individual sensors to it later as needed and install in minutes.
Kindle Unlimted 3-month Membership - $0.99 (Save $29)
Buying book after book after book can get pretty expensive very quickly, which is why Kindle Unlimited makes for the perfect alternative. Becoming a member unlocks access to Amazon's vast selection of digital books and more to read when you please, and they're all accessible via the free Kindle app which you'll be able to open and use practically anywhere you go. Now you can take all your favorite books with you without weighing down your luggage, and the best part is you can join today with a three-month membership for only $0.99.
Pageturner
Amazon Kindle Unlimited 3-Month Membership
Score three months of access to Kindle's digital eBook library for only $1 with this exclusive deal at Amazon. You'll be able to read the eBooks using the free Kindle app on a myriad of devices; no e-reader required.
$0.99 $29.99 $29 off
Answer the call: Mint Mobile 3-Month Plans
Mint Mobile is offering up to 40% off its service plans for three months when you join now! You can score any data plan for only $15 monthly for three months, though you'll need to pay the full three-month cost in advance.
Extra security: PureVPN
Security and privacy are important, but that doesn't mean you can't make a saving! This limited-time holiday offer at PureVPN drops the monthly cost to just $1.19 with code THRIFTER10. It works great on iOS, Android, macOS, Windows, and more.
Free radio: SiriusXM Essential 3-Month Subscription
This service launched earlier this year costs only $8 a month anyway, but you can get three months for free. The Essential bundle includes 300 channels of music, comedy, talk radio, and more. It's only for online streaming not using your car's satellite radio. Remember it will auto renew.
We may earn a commission for purchases using our links. Learn more.
