The Eufy RoboVac 35C self-charging Wi-Fi robot vacuum cleaner is down to $219.99 at Walmart. The same robot vacuum goes for over $250 at Home Depot. It also goes for as much as $291 on Amazon.
The RoboVac 35C connects to your Wi-Fi network so you can use your Amazon Alexa or Google Assistant smart home to control it. The vacuum is only 2.85 inches tall so it can fit under sofas, beds, and other low profile areas. It uses 1500Pa suction power and cleans for up to 100 minutes. When it runs low on power, it will return to the charging station before continuing its routine. You can also use the included boundary strips to help create an area you want to clean.
We may earn a commission for purchases using our links. Learn more.
