work gloves hero imageSource: Mechanics Wear
Best Work Gloves Android Central 2020
When it comes to protecting your hands and wrists during a long day of strenuous work, gloves are definitely the way to go. Not only are gloves great at shielding you from cold air and moisture while working outdoors, but they are also often made from tough and durable fabric that keeps your fingers safe. That's why we recommend the Custom Leathercraft 125M Handyman Flex Grip Work Gloves as they are made from durable leather and spandex, and they are great for use in extreme conditions.
Best Overall: Custom Leathercraft 125M Handyman Flex Grip Work Gloves
Custom Leathercraft work glovesSource: Amazon
The Custom Leathercraft 125M Handyman Flex Grip Work Gloves are an excellent choice for anyone who engages in hands-on work both indoors and outdoors. With their snug fit and durable fabric, these heavy-duty work gloves are designed to get the job done.
These Custom Leathercraft work gloves are made from strong and synthetic leather that is infused with flexible spandex and Lycra side panels. This ensures that the gloves provide dexterity and keep your hands protected while running machines, planting trees, or working on construction sites. The leather material resists shrinking and hardening from contact with moisture. Feel free to wear these work gloves while pressure washing a work site or while working on a dock or a boat.
They are great for wearing while working outdoors as well as the interior of these work gloves are insulated to keep your hands, fingers, and wrists warm during harsh winter conditions. If your hands become sweaty, you never have to worry about these gloves sliding off of your hand as they come equipped with a wing closing strap.
Although these work gloves are durable and flexible enough to cater to the needs of your job, some customers note that they don't last as long as expected with everyday use.
Pros:
  • Insulated
  • Feature wing closing strap, so they don't slip off
  • Made from synthetic leather and spandex
Cons:
  • Don't last as long as expected
Best Overall
Sturdy work gloves made from synthetic leather
These durable work gloves are made from synthetic leather and spandex. They're insulated and great for use indoors and outdoors.
Best Value: Vgo High Dexterity Heavy-Duty Mechanic Gloves (3 Pairs)
Vgo Work gloves lifestyleSource: Ebay
The Vgo High Dexterity Heavy-Duty Mechanic Gloves are a wonderful option for anyone who works with machines or in the construction industry as they are CA65 approved and comply with REACH regulations. These gloves feature an ergonomic design and come prepared for use with their three-dimensional hand modeling conform. You can rest easy knowing that your work gloves fit snug while still offering movement and dexterity.
These EN388 rated gloves are made from synthetic leather that is infused with PVC reinforcement. This provides extreme durability. These Vgo gloves also come prepared for the workplace with their EVA padding. This additional padding absorbs vibrations and impacts, ensuring that your hands remain safe. There is also thermal plastic rubber along the knuckles and fingers for added protection.
If your career requires you to use a smartphone while you work, then the Vgo High Dexterity Heavy-Duty Mechanic Gloves are an excellent choice as the fingertips, and thumbs feature a fabric that is compatible with a touchscreen. You won't have to remove your glove to use your smartphone.
These gloves come in a pack of three pairs, so you really get a lot of bang for your buck. To clean these gloves, simply throw them in the machine and hang to dry. The material in these gloves tends to hold moisture and can take a while to dry. This is good to remember while on a job site.
Pros:
  • EN388 rated, CA65 approved, comply with REACH regulations
  • Absorbs vibrations and impacts
  • Touchscreen compatible
  • Pack of three pairs
Cons:
  • Hold moisture and can take a while to dry
Best Value
Pack of three touchscreen compatible work gloves
These heavy-duty work gloves are touchscreen compatible and are incredibly durable. They come in a pack of three pairs.
Best for Cutting: NoCry Cut-Resistant Gloves
No Cry Work gloves lifestyle imageSource: My Central Jersey
If you work in a career that requires you to handle sharp objects or where you need to chop and slice frequently, the NoCry Cut-Resistant Gloves may be perfect for you. These work gloves come with an EN388 Level 5 rating, which means that they meet the European standards of testing and can withstand up to 7.7 pounds of weight on a blade without the material of the glove being cut through.
Not only are these gloves sturdy, but they are comfortable as well. The NoCry Cut-Resistant Gloves are made from a blend of glass fiber, spandex, and ultra-high molecular weight polyethylene, which is a material that is corrosion and wear-resistant. Together these fabrics are four times stronger than leather. You won't have to worry about accidentally cutting yourself while chopping and sizing materials for your job site.
These work gloves are prepared for women and men and come in four different sizes: small, medium, large, and extra-large. You can focus entirely on the task at hand as these gloves are made to feel like a second skin. You won't be distracted or hindered from work due to excess material.
It is important to note that although these gloves are cut-resistant, they are not cut-proof. Ensure that you remain cautious and careful while using sharp objects as injuries can still occur. Once you've finished your hard day at work, simply throw these gloves into the washing machine at a low temperature and hang to dry.
Pros:
  • Lightweight
  • EN388 Level 5 rating
  • Come in four different sizes
  • Machine washable
Cons:
  • Not cut-proof
Best for Cutting
Cut-resistant work gloves
These cut-resistant work gloves feature an EN388 Level 5 rating, which makes them great for protecting against sharp objects.
Best for Winter: Ergodyne ProFlex 817WP Waterproof Work Gloves
ergodyne work gloves lifestyle imageSource: Civil Gear Wordpress
If you're looking for a glove that is tough enough to keep your hands and wrists protected during cold winter months, then the Ergodyne ProFlex 817WP Waterproof Work Gloves are perfect for you. These gloves are both windproof and waterproof and made for extreme temperatures.
Featuring 3M Thinsulate, these dual-zone insulated gloves offer exceptional thermal protection to keep your hands safe and warm. There are 40 grams of insulation in the palms and 70 grams of insulation in the back of the hand to ensure your hands stay toasty in frigid temperatures. Although these gloves are heavily insulated, they remain lightweight and provide dexterity.
You don't have to worry about your hands slipping against icy or damp surfaces as these gloves are equipped with rugged AX suede in the fingertips and palms. This acts as a grip and offers some flexibility while dealing with objects in the cold. These gloves also come prepared with an index finger and thumb that are compatible with a touchscreen on smartphones and tablets, so you never have to take the gloves off.
Although these gloves are excellent for protecting you from extreme temperatures, some customers mention that the gloves fit tight, and the fingers can be a little too long for smaller hands.
Pros:
  • Dual-zone insulated for extreme temperatures
  • Waterproof and wind-proof
Cons:
  • Gloves fit tight, and fingers can be too long
Best for Winter
Dual-zone insulated work gloves
These dual-zone insulated work gloves are excellent for protecting your hands against freezing temperatures.
Best for Gardening: Pine Tree Tools Bamboo Working Gloves
Pine Tree Work Gloves Lifestyle ImageSource: Pine Tree Tools
If gardening and yard work is your obsession, then the Pine Tree Tools Bamboo Working Gloves may be just what you're looking for. These gloves are made from a breathable bamboo that absorbs sweat to keep your hands the perfect temperature in every season. Feel free to maintain your garden all year round.
These gloves are also great for fisherman as they offer a tough grip that is great for holding fish as well as a tough exterior that keeps you protected while changing hooks.
These work gloves offer a snug fit, which gives you the freedom and ability to maneuver your tools with ease. The Pine Tree Tools Bamboo Working Gloves have been proven to resist abrasions, so you can wear them to complete even the toughest jobs. These gloves are comfortable and durable. They will work just as hard as you do. Some customers mention that these gloves do tend to wear down sooner than expected with everyday use.
The fit on these Pine Tree Tools work gloves is tight and lightweight. They fit like a second skin and even offer bare-hand sensitivity. You can easily use touchscreen applications on your tablets or smartphones without needing to remove the gloves.
Pros:
  • made from breathable bamboo
  • Resist abrasions
Cons:
  • Wear down with every-day use
Best for Gardening
Breathable bamboo gloves for gardening
These abrasion-resistant gloves are made from breathable bamboo and are great for gardening. They're also touchscreen compatible.
Bottom line
Finding the right work gloves to keep up with the demands of your job is essential to your success. Not only do the gloves need to fit right, but they need to be durable as well. In addition to this, work gloves have to have the ability to protect your hands, fingers, and wrists from extreme temperatures. That is why we recommend the Custom Leathercraft 125M Handyman Flex Grip Work Gloves.
The Custom Leathercraft 125M Handyman Flex Work Gloves check all of the boxes. They are made from a mixture of strong, synthetic leather and spandex, which offers dexterity as well as insulation for your hands. They also feature a unique wing closing strap to ensure that they stay in place while you work. Your work gloves should feel like a second skin against your hands and set you up for success in the workplace.
Credits — The team that worked on this guide
Camille Sanghera is a freelance writer who loves using the power of words to give individuals and objects a voice. When she is not content writing, you can find her running trails with her dogs or writing fiction and self-help books.
We may earn a commission for purchases using our links. Learn more.
