Best Electric Brooms Android Central 2021
Have you ever found yourself spending more than a few moments trying to get the last little bits of dust and crumbs into your dustpan? Or how about lugging around your full-size vacuum to clean small messes? Electric brooms are the sweet spot between both cleaning methods. They're small and light enough to get into every corner with ease, and don't leave part of the mess behind. Here's a list of our favorites.
Dyson V8 Animal Cordless Vacuum
Lifetime filter: Dyson V8 Animal Cordless Vacuum
Staff Pick
Suited for picking up pet dander and dust, the filter on the Dyson V8 Animal is washable and will last you a lifetime. There's an on/off trigger, which will make sure all of your battery life is used for cleaning. If you are using this model on a hard surface without a motorized tool, you can get up to 40 minutes of use. For carpets, you can expect 25 minutes of use.
$289 at Amazon
Bissell PowerEdge Pet Hardwood Floor Cleaner
Excellent at edges: Bissell PowerEdge Pet Hardwood Floor Cleaner
The v-shaped foot has a swivel feature and is perfect for cleaning the edges and corners of hard surface floors. Dust and pet hair are funneled into the suction channel, which means there's no spinning brush to get tangled with hair. You'll never have to worry about running low on power since this model plugs into the wall.
$70 at Amazon
Hoover Linx Cordless Stick Vacuum
Easy battery switching: Hoover Linx Cordless Stick Vacuum
This Hoover model supports interchangeable batteries, so you can use one and charge one at the same time. You can change suction modes with a switch on the handle; the hard surface mode doesn't use the brush, and the carpet mode does. A press of a button will empty the dirt cup, keeping your hands clean.
$125 at Amazon
Dyson V11 Torque Drive Cordless Vacuum
Power meter LCD: Dyson V11 Torque Drive Cordless Vacuum
This latest iteration of the stick vac from Dyson runs for 60 minutes and can pick up 99.97% of microscopic dust particles. You'll always know how much time you have left to clean with the LCD display at the top of the unit. When you need to clean smaller spots, convert this model to a hand vacuum, or use the many included attachments for crevices or stubborn dirt.
$489 at Amazon
Bissell Featherweight Stick Vacuum
Budget-friendly: Bissell Featherweight Stick Vacuum
Weighing in at only 3 lbs, you'll be able to take this electric broom anywhere in your house. It offers the functionality of three machines in one: stick vacuum, handheld vacuum, and stair vacuum. There's a crevice tool for reaching tight spaces, like corners or between cushions, and the dirt cup is easy to empty.
$30 at Amazon
Tineco A11 Hero+ Cordless Vacuum
Extra battery: Tineco A11 Hero+ Cordless Vacuum
Unlike similar models, Tineco's A11 Hero+ lets you lock-on continuous power mode, so there's no trigger to hold while cleaning. The collection system offers four stages of filtration, which prevent dust from escaping back into your home. They've also included an extra battery so you can get all your cleaning done at once.
$260 at Amazon
MOOSOO Cordless 4-in-1 Vacuum
Clean air champ: MOOSOO Cordless 4-in-1 Vacuum
Maneuver around your home with ease thanks to the 120-degree swivel and LED-lighted front on this vacuum. It works on all floor types and can switch between hard and carpet surface modes to save battery. If clean air is a top priority, this is an excellent choice thanks to the included HEPA filter.
$120 at Amazon
Shark Rocket Ultra-Light Corded Vacuum
Home and auto: Shark Rocket Ultra-Light Corded Vacuum
Forget charging a battery; this model from Shark has a 25-foot power cord and is always ready for use. It's ideal for both your home and car since the micro tools to reach tight spaces are included with your purchase. Finding storage space won't be difficult with the included wall mount.
$170 at Amazon
Goodbye dust and pet hair
Cleaning isn't so bad when you have a lightweight machine to help with the floors and furniture. For most people who will use their electric broom with high frequency, we think the Dyson V8 Animal Cordless Vacuum is the best option. It's tough on pet hair, dander, and you won't ever have to replace the filter. The trigger switch allows you to only use the battery you need, instead of wasting power while you move across the house. And the 40-minute run time will make sure you don't need to stop to recharge.
For those who will only use their electric broom now and then, consider the Bissell Featherweight Stick Vacuum. You won't need to leave the battery charging all the time since this model uses a power cord. Additionally, it only weighs 3 lbs, making it easy to carry up or down your stairs.
We may earn a commission for purchases using our links. Learn more.
