If you're stuck driving around in an older car that doesn't feature Bluetooth, your chance to wirelessly stream music from your phone to your car radio still exists without buying a new car, and there are extremely affordable ways of going about it. TaoTronics has a couple of products on sale today that make it possible, and both are discounted by when you enter the correct coupon at Amazon
The TaoTronics Bluetooth Aux Adapter falls by $10 when you use code E6PVIW38 during checkout. It regularly sells for $26 and today's discount is the steepest we've ever seen for it.
Audio upgrade
This tiny Bluetooth adapter lets you start using Bluetooth in places you couldn't before, like your car or home speaker system. It even has a built-in mic for speakerphone calls. Enter the below coupon at checkout to score this low price.
$15.99 $25.99 $10 off
The rechargeable device connects to your vehicle's aux port and receives the Bluetooth signal from your phone or other device that you're playing music from. It supports Bluetooth 4.2 and aptX for a solid connection and high-quality sound. You can even connect two Bluetooth audio sources to it at once. You'll get around 15 hours of playtime before you have to recharge it and being totally wireless means you don't have to have a cable strewn across your car to a power source at all. There's a noise-cancelling mic for taking and making calls too.
Driver's choice
TaoTronics Bluetooth Car Kit
The bundle enables wireless audio via your car's AUX port, hands-free calls with its built-in mic, and keeps your phone powered up with the included car charger. Be sure to clip the on-page coupon & enter the below code to get the lowest price.
$15.99 $23.99 $8 off
If you don't want to worry about recharging your receiver, a better option would be the TaoTronics Bluetooth Car Kit. It's down to the same price at $15.99, an $8 savings. To get the lowest price, you must clip the coupon on its product page and then enter code TXNOLU48 during checkout. It comes with a vent-mouted Bluetooth receiver with easy-access playback controls, the necessary aux and power cable, as well as a dual-USB car charger to provide it, and another device, power. It also has an integrated mic for taking voice calls.
While you're kitting out your car, you probably want to go ahead and grab yourself a car mount for your phone. There are a bunch of different options to suit all types of vehicles, so put your savings to use with your preferred option.
We may earn a commission for purchases using our links. Learn more.
