Pocket Casts
Continuous playback over notifications and more bug fixes than you can shake a stick at
Since making the move to a completely new design with Pocket Casts 4, a few lingering bugs have been piling up. Those are getting squashed today, along with a few new feature adds, with a big update to the app today. First up, the update brings the option to have playback not be interrupted by notifications, which is still set to be off by default. The sharing menu for podcasts has also received a tweak that gives you three simple options -- email, other apps, copy link -- to cut down on the interface clutter. You can now mark every episode from a certain podcast as "unplayed", and long-pressing on the "next" button will skip to the next item in a playlist.
Some of the big user-facing bugs, such as duplicate episode downloads and action bar bugs that showed extra action buttons have been notably fixed. When episode downloads fail, they now properly show up in the "not downloaded" filter once again. There are also many more back-end issues that have been fixed as well. If you haven't had a chance to see Pocket Casts in action, now may be the time -- grab a download from the Play Store link above.
