Those of you rocking Android 2.2 already should know that Adobe Flash 10.1 has entered beta 3, so you'll want to update it (if you're not having it update automatically). Not sure if anything of substance has changed, so sing out in the comments if you spot something. [Adobe] Thanks, @iRyanM!
- Filed under:
- Tags:
3330(forum posts)
