The Motorola Droid X is synonymous with awesome smartphone, and Otterbox is synonymous with awesome smartphone protection. And with the Otterbox Commuter Series case for the Droid X ... you see where this is going. It's one solid case for your Droid X.
The Commuter Series case actually comes in two parts. There's a rubber skin that wraps around your phone, and then a plastic shell you slide on top. You might be tempted to only use the rubber skin, but it's a little too loose to use alone.
Every part of the phone save for the touchscreen is protected by the case. The buttons are all covered by the rubber skin yet remain completely accessible. The 3.5mm headphone jack and HDMI and microUSB ports have little rubber flaps that fit inside for protection. It can take a little finagling to get everything in place just so.
The plastic shell covers the back, top and sides of the Droid X. You'll likely need to work on the HDMI-microUSB cover a little bit to get it to fit right. And once it's in place, you have one solid case. It's important to note that the Droid X's secondary microphones are completely uncovered, so their performance isn't attenuated. Same goes for the camera.
The Commuter Series case adds a little bit of thickness to the Droid X. But the phone is so thin to begin with (despite being tall and wide thanks to its 4.3-inch screen), it really doesn't bother us much. It's also just thick enough to keep the screen from touching when left face-down.
We've got more pics after the break. The Otterbox Commuter Series case for the Motorola Droid X is available in the Android Central Store for $24.95.
2438(forum posts)
