Motorola Droid Bionic
Get the feeling that the Motorola Droid Bionic -- which is hitting stores sometime next month -- is in the hands of a few few testers? Yeah, us, too. Here's a new pic that was dropped into our forums. (Full disclosure: We've cropped out the beyond-spammy watermark on this pic; you can see the whole thing at the source links below.)
Anyhoo, not a whole lot to see here. Big battery (but will it be big enough?), the 4G LTE SIM card, and a spot for the microSD card.
Source: MyEGarageSale via Droid Bionic Forums
There are 16 comments. Add yours.
Vanilla Ice says:
Looks like easy MicroSD card access. Finally no more battery pulls!
moosc says:
Where do u see SD card? I see the sim card bet SD still under battery
tehsusenoh says:
The SD goes on top of the SIM.
moosc says:
Are u sure? Looks like my sim slot on my mifi and there's no room for a sdcard
GrillMouster says:
The microSD card slot appears to be on top of the sim card.
moosc says:
Is that a 1800 battery?
moosc says:
Single led flash
ChuckG73 says:
Are you sure and if so is that a bad thing?
Masheen says:
Yeah anybody got the mAh of that bat?
Mr. Fisk says:
I'm hopeing that batt is at lest 1900
The battery is 1900mah guys... But the screen in pentile, it's out of the running for me. That screen is god awful and pixel prone.
Vanilla Ice says:
Much better then the dx. The Bionic will not sell with a fail screen. qhd or not.
KillerG says:
Why would they not put the mAh on the battery? XD Damn you Motorola...probably the part that's in Chinese (or Japanese or whatever, I can't tell) would say the mAh on the battery.
Masheen says:
It is. It's written on the underside.
Ummm if you look closer there is a micro sd card in the slot and verizon runs on a cdma network there wouldn't be a sim card slot for this phone.
Bodero says:
4G LTE uses a SIM card....
