We're knee-deep into our Motorola Droid Bionic review (update: Read our comprehensive Droid Bionic Review!) but wanted to take a quick second to talk about the battery. Specifically, let's talk about the Droid Bionic's extended battery.
We're all in the midst of testing this dual-core LTE phone, hopefully will see better battery life than some of its predecessors. But an extended battery is definitely still an option, and this one bumps you up to 2760 mAh, from the stock 1735 mAh.
And the DB's extended battery doesn't add as much heft or girth to the phone as we'd feared. It does require an bigger batter cover, but it's nicely designed and while it makes the phone thicker, it does so in a pretty stylish manner and still feels pretty good in the hand. The larger battery door is nicely contoured and doesn't have nearly the same sharp lines as the extended battery door on the HTC ThunderBolt.
We've got more pics and hands-on video after the break if you're still on the fence. Check it out.
Motorola Droid Bionic Extended Battery | All Motorola Droid Bionic Batteries
- Related devices:
- Filed under:
- Tags:
2438(forum posts)
