Continuing our journey into the world of CyanogenMod themes, I present to you JAMT - White Gradient. A lighter colored theme, this is for the folks who want something brighter and more eye-catching on their phones.
The most striking feature of JAMT - White Gradient is the notification status bar. It's completely rebranded the same bright silver color that is seen throughout the entire theme, and makes all the text and icons grey. It's the first thing that really caught my eye, and if you're used to seeing typical Android phone homescreens, it really sticks out.
The icons are also different on the notification bar, namely wifi and the Gmail icon. Sliders (volume, timers for Drocap, anything) are also a nice silverish grey color. Toast notifications have a completely black background with sharp corners instead of rounded edges.
The developers says there are a whole slew of icons that're themed, but the only one that shows up on my phone is Drocap. I'm not sure if that's a limitation of the theme or if it's because my phone is running an alpha of CM7, but be aware.
The dialer is also nice and bright, in stark contrast to the typically dark dialer seen on most AOSP devices. It's actually pretty cool looking, and if I end up going the silver/white route, that'll probably be a reason I settle on this theme.
There's both a free version and a donate version ($1.00) in the Market, so you can definitely try before you buy. If JAMT - White Gradient looks like something up your alley, we've got more pictures and download links after the break.
- Filed under:
- Tags:
- android
- app
- App review
- classicalgas
- cm7
- grey
- jamt
- silver
- theme
- theme chooser
- theme review
- white
- white gradient
30(forum posts)
