UGREEN only just released its USB-C Portable Power Bank, but you can already save on it. All you have to do is add it to your cart and enter UGREEN399 during checkout. That code will take just over $7 off its price in its first ever sale.
All juiced up
UGREEN USB-C Portable Charger
With a 10,000mAh capacity, it can charge your phone multiple times over. Its USB-A and USB-C ports make it really versatile, too.
$14.94 $24.29 $9 off
The charger has a 10,000mAh battery inside which has enough capacity to recharge an iPhone 8 four times or a Samsung Galaxy S10 twice over. It has a regular USB-A port with support for Quick Charge 3.0 speeds, or you can make the most of Power Delivery with its USB-C port if you want to get your compatible device powered up as quickly as possible. Both ports can be used simultaneously, too. The USB-C port is used as an input for recharging the power bank itself and the built-in LED display will let you know exactly when to do that, though you might want to pick up a USB-C cable and wall charger for doing so if you don't already have them.
We may earn a commission for purchases using our links. Learn more.
