Amazon usually sells this Teckin Smart Power Strip for $27.99. Today, however, you can drop the price to $22.95 simply by entering coupon code I8HTYBWU during checkout. This product rarely deviates from the normal price point, and it hasn't dropped as low as today's deal in over a year. Now makes the perfect opportunity to pick up a gadget that can turn old tech into something smarter.
Plug It In
Teckin Smart Power Strip Surge Protector with 4 USB Charging Ports
With four AC outlets and four USB ports, this smart strip can take your tech to new levels.
$22.95 $27.99 $5 off
With coupon: I8HTYBWU
Once connected, this smart strip can be used in conjunction with a free app for independent control over each outlet. There are four AC ports and four USB ports, meaning you can connect several different devices. Automate appliances, set schedules for lights, set timers, and save energy thanks to the usage insights the app will give you. The smart strip is also compatible with home assistants like Google Assistant and Amazon Alexa, so you can say a few words to take control over connected devices. The cable also measures five feet long, so you should be able to find a convenient spot to place your new power strip. Teckin backs your purchase with a two-year warranty.
We may earn a commission for purchases using our links. Learn more.
