There are few things more annoying than trying over and over again to light a lighter, only to realize that you're out of fluid. With a Tacklife Electric Arc Lighter, you'll never run into that problem again. The last lighter you'll ever need falls to just $6.48 when you enter code E5VGOFJW during checkout at Amazon. That's the lowest we've ever seen it reach and a deal which saves you nearly $7 off its price otherwise.
LIGHT EM UP
Tacklife Electric Arc Lighter (2600mAh)
This inexpensive lighter can be recharged hundreds of times, making its battery far outlast any other one you have.
$6.48 $12.97 $6 off
Tacklife T8 800A Peak 18000mAh car jump starter with LCD display and quick charger
Works on most cars, SUVs, trucks, and more. Can jump start up to 30 times on a single charge. Charge mobile devices with two USB ports and an 18000mAh capacity. Even has Quick Charge and a built-in LED flashlight. Covered by a two-year warranty.
Tacklife Power Station 300W
Getting off the grid for a while is easier with Tacklife's new Autumn Exclusive Power Station. This 300w portable solar generator drops nearly $100 in price when you use the following promo code during checkout.
Tacklife 1200A Car Jump Starter (KP120)
Packing for your summer road trip won't be complete without ensuring you can jump-start your vehicle's battery in a pinch. This 1200A peak model is suitable for up to 8L gas or 6L diesel engines. Use the 5% on-page coupon and the below code to save.
Tacklife 2-in-1 Magnetic Wristband and Waistband
Keep nails, drill bits, screws, and other parts readily available using this handy wristband. It's now nearly 50% off at Amazon, no coupon required.
Tacklife 2600mAh USB-rechargeable electric arc lighter
The lighter has a 2600mAh battery that's USB rechargeable. No gas. No mess. No smell. Just fire. Burn baby, burn. It's wind and rain proof and has a flexible neck for hard to reach spots. Comes with a lifetime warranty.
This lighter features a built-in USB rechargeable battery. Each charge provides over 1000 ignitions, and the battery itself can be recharged over 500 times, making your purchase a very wise investment. There's no spark or smell, and the long handle keeps your hand safe. The rotatable neck means that whether you're lighting up a candle or something smokable, you can always get the optimal angle. The lighter itself is lightweight and resistant to wind, and should anything go awry, your purchase includes a lifetime warranty.
We may earn a commission for purchases using our links. Learn more.
