The Apeman C450 1080p car dashboard camera is down to $27.19 with code RLNCTFCY on Amazon. We haven't seen this dash cam go on sale since the end of May, and it sells for around $40 or more when not discounted through codes like this.
For the car
You never know when something crazy will happen. Catch every incident, even the funny and innocent ones, on video so you can have it for later.
$27.19 $40.00 $13 off
Apeman 1080p HD Dual Dash Camera (C420)
Apeman's 1080p Dual Dash Cam records in front of and behind your vehicle with a 170-degree ultra wide angle lens to capture multiple lanes of traffic in one shot. Clip the coupon on its product page and use the following code at checkout to save.
Apeman 1080p Dual Dash Cam
Apeman 1080p HD Mini Portable Projector
This 1080p HD dash cam is equipped with a 3-inch LCD screen so you can review your footage even while on the road. Its 170-degree wide angle lens captures three lanes of traffic simultaneously, while the camera's built-in G-sensor automatically saves footage when a sudden shake or collision is detected to ensure the footage isn't overwritten. There's also clear night vision, seamless loop recording, and a parking monitor. It's really easy to set up, too.
The cam does not come with a microSD card, but you will need one. It supports cards up to 32GB so grab one from Samsung for less than $8.
We may earn a commission for purchases using our links. Learn more.
