We have a lot of electronics these days, which means there are a lot of things at any given time that need to be charged. Odds are you have a bunch of cables laying around, but not always the wall adapter, and that's annoying. You can solve that problem with easy by installing one of these USB Wall Outlets in your home. It offers both a USB-C and USB-A port, so all you'll need is that cable to power your devices.
They are a direct replacement of an existing electrical outlet, but you'll want to ensure you are comfortable with doing the job before you start. Be sure to turn the power to that outlet off, have the tools you need to do the job handy, and take your time. If you want one but aren't comfortable doing it yourself, contact a local electrician, they generally don't charge much to do the replacement.
If you don't need the USB-C port, or think having two USB ports is better for you, this option from Leviton is down to just $14.64, so be sure to pick up a couple of those.
TL;DR
  • What makes this deal worth considering? - This is the lowest price ever for this item. The Top Greener USB-C Outlet easily replaces any standard wall outlet.
  • Things to know before you buy! - You'll want to ensure you are comfortable with installing this before you try. Make sure the power to the outlet is off, and if you need to, consult a professional before attempting it. Prefer two USB-A ports? Check out this option from Leviton for $14.64.
See at Amazon
This post may contain affiliate links. See our disclosure policy for more details.
