Samsung Galaxy Z Flip 7 vs. Galaxy Z Flip 6: All about the cover screen
Samsung didn't think outside the box with the Galaxy Z Flip 6, bringing fairly minor upgrades to the popular foldable. With the new Samsung Galaxy Z Flip 7, there are more significant upgrades, but also much of the same. A bigger cover screen and slimmer design represent some of the key changes, and stalling performance and camera updates are a few holdovers.
More importantly, the Galaxy Z Flip 7 leaves Qualcomm behind in favor of Samsung's own Exynos 2500 processor. For people who prefer Snapdragon over Exynos, that makes things complicated. There is enough overlap to make both the Galaxy Z Flip 7 and Galaxy Z Flip 6 attractive to the right kind of person, so which should you buy? Let's find out.
For more news and information on Samsung’s latest foldables, check out our Ultimate Guide.
Samsung Galaxy Z Flip 7 vs. Galaxy Z Flip 6: Display and design
Samsung Galaxy Z Flip 7 Cover Screen hands-on
(Image credit: Andrew Myrick / Android Central)
The Samsung Galaxy Z Flip 7 features much slimmer bezels and larger displays, both internally and externally, making for a fresh look overall. The outer cover screen is significantly larger, expanding from the 3.4-inch AMOLED display on the Galaxy Z Flip 6 to a 4.1-inch AMOLED screen. Samsung also claims that it has the smallest beel found on a foldable phone. Additionally, the screen refresh got a significant boost, increasing from 60Hz to a buttery smooth 120Hz.
The main screen got a bump too, growing to become a 6.9-inch Dynamic AMOLED 2X panel. That replaces the older 6.7-inch Dynamic AMOLED 2X LTPO display on the older Galaxy Z Flip 6. Aside from the display and size changes, the overall form factor of the two foldable generations is quite similar between models. Both have a rectangular, boxy design with slightly chamfered edges.
Samsung Galaxy Z Flip 7 hands-on
The big difference between the two models is their thickness and weight. The newer Galaxy Z Flip 7 measures 85.5 x 75.2 x 13.7 mm when folded, and weighs only 188 grams. That's slightly heavier than the Galaxy Z Flip 6, but much thinner. When unfolded, you'll notice the bigger inner screen on the Galaxy Z Flip 7 compared to the older Galaxy Z Flip 6.
Both phones are durable, supporting IP48 certification against dust and water ingress. They also feature Armor Aluminum side rails and a durable FlexHinge that keeps a low profile. Further protection is added by the Gorilla Glass Victus 2, which should help them better survive 1-meter drops onto conrete-like surfaces.
Samsung Galaxy Z Flip 7 vs. Galaxy Z Flip 6: Hardware and specs
Samsung Galaxy Z Flip 6 cover screen
(Image credit: Derrek Lee / Android Central)
Performance is the highlight of the Galaxy Z Flip 7, which opts for the Exynos 2500 processor instead of the industry-leading Snapdragon 8 Elite. Despite the apparent downgrade, Samsung claims the 3nm Exynos 2500 chip provides more power than the Snapdragon 8 Gen 3 processor inside the older Galaxy Z Flip 6.
We've performed our own tests to see just how well it performs, which you can check out here. Long story short: Exynos still can't match Qualcomm, but it's getting closer.
An Exynos processor paired with a larger battery capacity could make the Galaxy Z Flip 7 the longest-lasting Galaxy clamshell foldable yet. This phone includes a 4,300mAh battery, replacing the Galaxy Z Flip 6's 4,000mAh cell. This, paired with the more efficient display and processor, should result in a markedly improved uptime compared to the Galaxy Z Flip 6.
Swipe to scroll horizontally
Category
Display
6.9-inch, 2520 x 1080, FHD+, Dynamic AMOLED 2X, LTPO (1-120Hz)
6.7-inch Dynamic AMOLED 2x, LTPO (1-120Hz), 2640 x 1080 resolution, 22:9 aspect ratio, 2600 nits
Cover display
4.1-inch Super AMOLED, 60/120Hz, 948 x 1048
3.4-inch AMOLED, 60Hz, 720 x 748, 306 ppi
Operating System
Android 16 (One UI 8)
Android 14 (One UI 6.1.1), upgradable to Android 15
Chipset
Samsung Exynos 2500
Snapdragon 8 Gen 3 for Galaxy
RAM
12GB
12GB
Storage
256GB, 512GB
256GB, 512GB
Rear Camera 1
50MP, f/1.8 wide
50MP wide, f1.8, 1.0μm, Dual Pixel AF, OIS, 85˚
Rear Camera 2
12MP, f/2.2 ultrawide
12MP ultrawide, f2.2, 1.12μm, 123˚
Front-facing Camera
10MP, f/2.2 wide
10MP wide, f2.2, 1.22μm, 85˚
Battery
4,300mAh
4,000mAh
Charging
25W wired charging, 10W wireless charging, 4.5W reverse wireless charging
25W wired charging, 15W fast wireless charging 2.0, 4.5W reverse wireless charging
Connectivity
5G, Wi-Fi 6E, Bluetooth 5.3, NFC
Weight
188g
187g
Dimensions (folded)
71.9 x 85.1 x 14.9mm
Dimensions (unfolded)
166.7 x 752.2 x 6.2 mm
71.9 x 165.1 x 6.9mm
Protection
IP48, Armor Aluminum frame, Gorilla Glass Victus 2 (cover display, rear panel), PET screen protector (inner display)
The software improvements continue, as the Galaxy Z Flip 7 starts off with One UI 8, based on Android 16. It's the first set of Galaxy foldables to launch with the newest Android version. In fact, the Galaxy Z Flip 7 is one of the first Android phones to run Android 16 out of the box.
Naturally, all the Galaxy AI goodies featured on the Galaxy S25 series will make their way to the Galaxy Z Flip 7 as well. There are some unique tricks, too, like Gemini Live with camera support on the Flex Window cover screen.
Samsung Galaxy Z Flip 7 vs. Galaxy Z Flip 6: Cameras
Selfie camera using cover screen on Galaxy Z Flip 7
The Samsung Galaxy Z Flip 6 finally bumped the primary camera of Samsung's more stylish foldable lineup. Unfortunately, there are no camera upgrades for the Galaxy Z Flip 7. That said, the Galaxy Z Flip 6 produces very respectable images with impressive zoom quality and color reproduction. It's not the best, but it definitely gets the job done.
Therefore, we have identical cameras on the Galaxy Z Flip 7, with the primary sensors being 50MP wide and 12MP ultrawide cameras. The front-facing camera is still the same 10MP, f/2.2 lens as well. Any camera quality improvements on the Galaxy Z Flip 7 will likely come from software tweaks.
Samsung Galaxy Z Flip 7 vs. Galaxy Z Flip 6: Which one should you buy?
The Samsung Galaxy Z Flip 7 probably doesn't bring enough to the table to warrant an upgrade if you own a Galaxy Z Flip 6 already. The cameras and charging speed are the same, and it's unclear whether the Exynos 2500 chip is an upgrade or a downgrade. The larger screens and Samsung DeX support probably aren't enough to sway Galaxy Z Flip 6 owners.
If you're not a Galaxy Z Flip 6 owner, though, getting the latest version of Android out of the box, along with tons of fun AI features and the promise of seven years of OS and security updates, is reason enough to buy the Flip 7.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
