Samsung Galaxy Z Flip 7 FE vs. Galaxy Z Flip 6: The same but different
Samsung's budget foldable looks a lot like its last-generation model.
A cheaper Samsung foldable
Samsung took the Galaxy Z Flip 6, gave it an Exynos chipset, and lowered the price to make the new Galaxy Z Flip 7 FE. On paper, it seems like the natural pick for people wanting a Galaxy foldable on the budget. However, weaker performance and a lower storage capacity might hamper the value proposition.
Pros
- Same design and displays as Galaxy Z Flip 6
- Costs less than a new Galaxy foldable
- Ships with One UI 8 and has excellent software support
Cons
- Older Exynos 2400-series processor
- Limited battery capacity and 25W wired charging speeds
- Still somewhat overpriced
The last-gen Flip
The Samsung Galaxy Z Flip 6 was just replaced by the Galaxy Z Flip 7, but that doesn't mean it's down for the count. Many of its features and qualities live on in the cheaper Galaxy Z Flip 7 FE. This model has the advantage of a Snapdragon processor rather than an Exynos one.
Pros
- Still has 6+ years of software support remaining
- Premium design with excellent durability
- Qualcomm Snapdragon 8 Gen 3 for Galaxy chipset
Cons
- Slow wired and wireless charging speeds
- Limited usability of cover screen
- Lacks performance of newer Android phones
Samsung just released a lineup of new foldables, and that includes a cheaper Galaxy Z Flip model for the first time. The upcoming Samsung Galaxy Z Flip 7 improves on the Galaxy Z Flip 6's offerings, but the budget Galaxy Z Flip 7 FE copies them instead. Nearly all current Galaxy Z Flip 6 features were simply carried over to the more affordable Galaxy Z Flip 7 FE.
Does that mean you should just buy a Galaxy Z Flip 6 now instead of the Samsung Exynos-powered Galaxy Z Flip 7 FE? It's complicated. There are key ways that the last-generation model might beat the budget model and vice versa. Unfortunately, Samsung didn't hit the price point we were hoping for. As such, the Galaxy Z Flip 6 might actually be a better value than the Galaxy Z Flip 7 FE.
For more news and information on Samsung’s latest foldables, check out our Ultimate Guide.
Samsung Galaxy Z Flip 7 FE vs. Galaxy Z Flip 6: Pricing and availability
The Samsung Galaxy Z Flip 7 FE was announced alongside the Galaxy Z Flip 7 and the book-style Galaxy Z Fold 7. All three were revealed at a launch event in New York City on July 9, 2025. The smartphone starts at $899 for the 128GB configuration, and there's also a 256GB model available. You can only pick from black or white colorways.
You can go out and buy the Samsung Galaxy Z Flip 6 right now, as it has been out for about a year. It retails for $1,099 and became available on July 24, 2024. You can choose between 256GB or 512GB of storage, but both configurations come with 12GB of RAM. There are a handful of colorways available, including Silver Shadow, Yellow, Blue, and Mint. If you buy from Samsung's online store, you can get exclusive options of Crafted Black, White, and Peach.
Soon, it's possible the Galaxy Z Flip 6 comes down in price to make way for the newer models, potentially competing with the Galaxy Z Flip 7.
Samsung Galaxy Z Flip 7 FE vs. Galaxy Z Flip 6: Design and display
The Samsung Galaxy Z Flip 7 FE matches the design language of the current Galaxy Z Flip 6, including the folder-style cover screen. It goes right down to the dimensions: both phones measure 85.1 x 71.9 x 14.9mm when closed. That means neither device is as thin as the new Galaxy Z Flip 7, and you probably won't be able to tell the difference between the FE and the Galaxy Z Flip 6 from the outside.
Both have an IP48 certification against dust and water ingress and Gorilla Glass for the cover screen and rear glass. These have become durability staples of Samsung foldables like the Galaxy Z Flip 6, so it's no surprise they're here on the Galaxy Z Flip 7 FE.
Additionally, the Galaxy Z Flip 7 FE is equipped with the same 6.7-inch OLED inner display as the Galaxy Z Flip 6. It also has the same 3.4-inch cover screen as the older model. Both models have an FHD+ Dynamic AMOLED 2x inner screen and a Super AMOLED outer screen.
The main display supports 120Hz variable refresh rates, while the cover screen only supports 60Hz. By reusing display panels from the Galaxy Z Flip 6, Samsung might've cut costs for the Galaxy Z Flip 7 FE.
The Samsung Galaxy Z Flip 7 FE is offered in more limited color options than the standard Galaxy Z Flip 6. Only black and white color options are available for the Galaxy Z Flip 7 FE, but the Galaxy Z Flip 6 can be had in a total of seven colorways.
Samsung Galaxy Z Flip 7 FE vs. Galaxy Z Flip 6: Hardware and specs
The biggest separator between the Galaxy Z Flip 7 FE and Galaxy Z Flip 6 is their processors. Samsung moved to its own Samsung Exynos processors for the Galaxy Z Flip 7 series this year, including both the flagship model and the "Fan Edition" model. The Galaxy Z Flip 7 FE is powered by the Samsung Exynos 2400 chip, which is built using the older 4nm process.
It's not on par with either the Exynos 2500 in the Galaxy Z Flip 7 or the Qualcomm Snapdragon 8 Gen 3 for Galaxy processor in the Galaxy Z Flip 6. People who love Qualcomm Snapdragon chips might immediately prefer the Galaxy Z Flip 6 for this reason. There's also less RAM on the FE, which will affect the performance and AI capabilities.
Category |
Samsung Galaxy Z Flip 6 |
OS |
Android 16 (One UI 8) |
Android 14 (One UI 6.1.1, upgradeable) |
Colors |
Black, White, |
Blue, Yellow, Mint, Silver Shadow (Samsung exclusive Crafted Black, White, Peach) |
Screen Sizes |
6.7-inch (inner) 3.4-inch (outer) |
Screen Resolutions |
2,640 x 1,080 (inner) 720 x 748 (outer) |
Screen Types |
FHD+ Dynamic AMOLED 2x (inner) Super AMOLED (outer) |
Refresh Rates |
120Hz (inner) 60Hz (outer) |
Processor |
Exynos 2400 |
Snapdragon 8 Gen 3 |
RAM |
8GB |
12GB |
Storage |
128GB, 256GB |
256GB, 512GB |
Cameras |
50MP main, 12MP ultra-wide, 10MP front |
Speakers |
Stereo Speakers (Dolby Atmos) |
Battery |
4,000mAh |
4,000mAh |
Wireless Charging |
Yes (15W) |
Yes (15W) |
Bluetooth |
5.4 |
5.3 |
Water Resistance |
IP48 |
IP48 |
Cellular |
5G |
5G |
Sizes |
165.1 x 71.9 x 6.9mm (open), 85.1 x 71.9 x 14.9mm (closed) |
Weight |
187 grams |
187g |
The phone keeps the Galaxy Z Flip 6's 25W wired charging speeds and 15W wired charging speeds. It uses a relatively small battery capacity and slow charging speed, which may be off-putting to potential buyers.
The cameras are the same across these two models as well. Both Galaxy Z Flip phones feature a 50MP main sensor and a 12MP ultrawide lens on the back. The front-facing camera is a 10MP sensor that's similarly unchanged. The new 50MP main camera was added to the Galaxy Z Flip 6 this year, so it's the best we've seen in a Samsung foldable.
Samsung Galaxy Z Flip 7 FE vs. Galaxy Z Flip 6: Which should you buy?
The Samsung Galaxy Z Flip 7 FE and the last-gen Galaxy Z Flip 6 share so many similarities that it's difficult to choose between the two. Still, we can help you narrow down your options. The major difference between these two phones is their processor. If you absolutely have to have a Qualcomm Snapdragon chip, the Galaxy Z Flip 6 is your only option.
However, there may be key advantages to going with the Exynos-powered Galaxy Z Flip 7 FE instead, such as battery life, efficiency, and AI improvements. For many, it'll come down to price. The Galaxy Z Flip 7 FE tries to hit an attractive price point, but frankly, it should've been cheaper to secure a good value proposition.
It's crucial to remember that the Galaxy Z Flip 6 will start seeing major discounts, too. All things equal, the older model will likely be better for most people.
Worth the savings?
The Samsung Galaxy Z Flip 7 FE and Galaxy Z Flip 6 are so similar that it's both hard (and easy) to choose between them. It comes down to processor and price. Can you live with an Exynos chip to save a few hundred dollars? If so, the Galaxy Z Flip 7 FE is for you.
Still a very good buy
The Samsung Galaxy Z Flip 6 is still the top (and only) option for a brand-new Galaxy clamshell foldable. It'll remain a great choice even after the Galaxy Z Flip 7 FE debuts, as it sports a Snapdragon processor. Plus, it's due to see more deals and discounts.
Brady is a former contributor for Android Central, who wrote for the site from 2023 to 2026. With a focus on news, phones, and audio, he spent years reporting and commenting on all things related to consumer technology.
Brady reviewed Apple, Google, Samsung, and Motorola phones for Android Central, and attended industry-wide events like IFA and MWC on behalf of the publication. He holds a bachelor's degree in journalism from St. John's University.
His work has been published in XDA, Android Police, Android Authority, MakeUseOf, and SoundGuys, among other sites. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
