The Epicka universal international USB-C travel adapter is only $17.51 thanks to a 20% off on-page coupon at Amazon. Without the coupon it sells for $22 and has never dropped this low directly.
Jet Setter
This international travel adapter includes an AC outlet, four USB ports, and one USB-C port that can all be used simultaneously.
$17.51 $22.00 $4 off
The adapter can work in more than 150 countries and gives you access to plugs from the U.S., U.K, Europe, Australia, and New Zealand. Basically if you plan on traveling and still need to plug in your laptop or other device, take this with you. In addition to the plugs, it also has four USB-A ports and one USB-C port so you can charge six devices simultaneously. The adapter has a max power of 880W at 110Vac or 1840W at 230Vac. There are plenty of safety features to keep you from doing anything dumb. Keep in mind it does not convert electrical output current and voltage. The adapter comes with a one-year warranty.
We may earn a commission for purchases using our links. Learn more.
