Verizon has focused heavily on connecting Enterprise-ready software with your smartphone at this year's CTIA conference, and yesterday it announced its next step. The Mobile Unified Communicaitons Client (Mobile UC), availble on the Droids X, X2, 2 and 2 Global, and the Pro. Verizon says that more manufacturers and models will be compatable soon.
Mobile UC is designed to connect your personal and business numbers and make both simultanesouly available on your personal smartphone. Business calls will direct to your device when it is in business profile, and personal calls will be available when the business profile is turned off. Everything is Enterprise ready, with business calls (inward and outward) routing through your existing IP PBX system. And yes, when placing calls from your business line, caller IDs on the receiving end will display your business number.
When you're not on the move, Verizon is offering a Mobile UC docking station for your office: plug your smartphone in and calls you place will be routed through your business number and ethernet, without using personal minutes or data. Mobile UC is compatable with most Cisco and Avaya telephone systems, and set up must be done through your IT department. Once configured, you can download the app through Verizon's VCast. The service will cost $7/month, and the docking station will set you back $125. Hit the source link for Verizon's Mobile UC page.
Source: Verizon Wireless
23(forum posts)
