LG G Flex Vest
Two cases with distinct functional differences
Android Central @ CES
Accessory support for the recently-announced G Flex is a little light at the moment, but LG is at least showing off early versions of two cases for the bendy behemoth. The QuickWindow and Vest, as they're called, are similar in styling and materials but serve to distinctly different purposes.
The QuickWindow, on one hand, is much the same as we've seen for previous LG devices like the Optimus G Pro and completely covers the front and back of the G Flex. You're getting a hard outer shell with an interesting faux metal pattern on it, a nice stitched material where the front hinges on and a cutout in the screen cover portion to show you bits of information when closed.
With the Vest case, you're getting something a bit more minimalist. The basic idea is to simply protect all four corners of the G Flex against occasional bumps and scratches, while leaving most of the sides and back open to the air. Made of the same material and color as the QuickWindow, it gives a bit more visual flair with interesting cutouts along the edges and a solid portion down the middle of the back plate.
Be sure to take a closer look at the cases with our photo gallery after the break.
LG G Flex VestLG G Flex Vest
LG G Flex Vest case
LG G Flex QuickWindowLG G Flex QuickWindow
LG G Flex QuickWindow case
