LG G3 vibration strength
We've all been there, missing calls, texts, emails while our smartphone is in our pockets because we didn't feel the vibrate go off. Or perhaps you're tired of it shaking your desk to pieces every time it goes off. Fortunately, if you're the proud owner of a new LG G3, there's something you can do about it pretty easily.
Adjusting vibration strength is built right into the main settings menu on the G3. Head into Settings > Sound > Vibrate strength first of all. When you do you'll see the box presented here with three sliders to adjust individual vibration strengths for incoming calls, notifications and for when you tap the screen.
As you move the sliders up and down the phone will vibrate at that level for you to check your happy before hitting OK. Another little tip is how to quickly turn on vibrate only mode, easily done from the notification tray. There's a toggle that will say either "Sound," "Vibrate" or "Silent" depending on which mode the phone is currently in. Tapping it will cycle between the three.
That's all there is to it. Hopefully now your LG G3 will vibrate away as strong, or as weakly as you'd like!
For more, see our LG G3 help page, and swing by our G3 forums!
