You don't always want to have to choose between an easy snap-on cover and all-over protection for your phone. Sometimes it's more convenient to have the option to switch things up as and when you need, and that's one of the main strengths of Qmadix's snap-on cover with holster for the Galaxy Nexus.
Firstly, you've got a basic snap-on cover that's finished in soft-touch plastic, with a grooved pattern on the back for easy gripping. This can then slide into the holster component, which is equipped with a rotatable clip for attaching the entire package to clothes, pockets or bags. The inside of the holster faces the screen, and is so it's lined with a soft material to avoid scratches. And the cover, holster and phone all lock together securely, meaning you shouldn't need to worry about working its way free or falling out of the case while you're out and about.
The case's best feature by far is its ability to clip onto clothing, and offer multiple levels of protection based on what you're doing. If your phone is in your pocket, simply use the snap-on cover alone. If you need to clip it onto a belt or throw it in a bag without risking screen damage, just attach the holster and you're good to go.
The Qmadix Snap-on Cover with Holster is designed for both the international GSM Galaxy Nexus, as well as the Verizon LTE version, so whichever model you have, the case will fit snugly.
We've got more pictures for you after the jump.
- Related devices:
- Filed under:
- Tags:
36(forum posts)
