Droids you're probably not looking for
Verizon is officially pushing the Android 2.3 updates out to the Droid Pro and the Droid 2 Global over-the-air today.  Besides the features you would expect from Gingerbread, the Droid 2 Global update includes the following fixes and enhancements:
  • Improvements in stability prevent lockups, resets and force
  • close errors.
  • Bluetooth devices will now select the correct audio recording level for optimal voice capture and alert you when your audio level is too low.
  • Improved battery life while using Bluetooth.
  • Access My Verizon without any force close errors.
  • Reset Backup Assistant under Manage Applications menu.
  • Enhanced connectivity when roaming in GSM/UMTS networks
  • (Europe and India).
  • Improved battery life during Wifi use.
  • Exchange ActiveSync encryption fails after OTA update.
  • Google Books added
  • Accuweather added
  • Amazon MP3 Store added
  • Blockbuster added
  • Adobe Flash Player 10.2 added
Not to be left out in the cold, the Droid Pro also see some much needed fixes and enhancements:
  • Improved contact syncing from multiple email accounts.
  • Improved battery life while using Wifi and/or Bluetooth.
  • Correct contact name is displayed when receiving SMS messages.
  • Forward SMS message conversations correctly.
  • Mobile Hotspot status is displayed accurately.
  • Clock widget updates time correctly.
  • GPS apps and programs no longer cause unnecessary device resets.
  • V CAST Media Manager now comes preloaded.
For more information about the updates, and download and installation instructions, visit the Droid Pro update page and the Droid 2 Global update page.
There are 10 comments. Add yours.
icemanhcj says:
Got mine for global2 on saturday. Works great so far.
Now if I can just get it for my
charge.
They should have just skipped that update and gone with ice cream sandwich.....
btc0526 says:
You do realize ics was just announced right?
n0obpr0 says:
one can always hope you know...
El Jefe says:
There is a difference between hoping & just being delusional though. LOL!
People say the exact same thing when any new Android version is released but it's never going to happen for a device to completely skip an update & go to the newest.
NO ONE is going to get ICS (officially) before the Galaxy Nexus is released & only a few weeks or month after will the Nexus S (& possibly the Nexus One) get it. No other device will get it for probably a few months. It's been that way since before Eclair (2.1).
trmoney24 says:
so i updated mine to GB long time back when it leaked out. i wonder if this update is different than what I got back then?
http://forums.androidcentral.com/motorola-droid-pro/91235-how-update-gin...
hotkoko says:
Yeah same here. I got that update months ago, I did it manually. I wonder if its the same version. If its a different one, will we get the update?
hotkoko says:
Is the version pushing out 2.3.3 or 2.3.4? I've had 2.3.3 for months.
Well if it's the same version that my mom got weeks ago for her Droid Pro it's 2.3.3. I checked her phone today after I read this and it says there is no new updates.
whatwhat says:
My Thunderbolt weeps.
