Our friends at Thrifter are back again, this time making it more affordable to keep lots of power with you all the time!
Update: These popular battery packs are on sale again with new coupon codes. Be sure to grab one now!
Right now you can score some sweet savings on Kmashi's portable battery packs at Amazon with a coupon code. For as little as $9 you can grab a 10000mAh power bank to charge your favorite gadgets while on the go without tethering yourself to a wall. The batteries are rather small and high capacity, ranging from 5000mAh to 15000mAh. The higher capacity models both have two USB outputs to charge multiple devices at the same time if needed, and recharge via microUSB.
Kmashi battery
These two are currently on sale with coupons:
If you find yourself needing extra power during your day, you will want to have one of these around. At these prices, you may want to pick up some gifts for others as well. Be sure to act quick, as this deal likely won't last long.
See at Amazon
For more great deals be sure to check out our friends at Thrifter now!
