With the Lenovo Mirage Solo coming out, you might be wondering how you can take it around with you wherever you go. Since it is USB-C, you can't go to any store to grab any charger that they sell.
These are the best ways to keep your Lenovo Mirage Solo going while on the go.
See the Lenovo Mirage Solo at Amazon
Anker PowerCore+ Charger
This Anker portable charger is a great option for someone who doesn't mind spending a bit of extra cash on a charger. For $66, you get a 20100mAh charger with a USB to USB-C, a USB-C to USB-C, and a USB to microUSB port.
Although it is expensive, it's a great charger if you're willing to spend that kind of money.
Anker PowerCore Compact Charger
Another great charger by Anker that will cost you less money than their larger charger. This charger has 13000mAh and two ports for USB to USB-C and it comes with a microUSB to USB so you can charge it. If you don't have a USC to USB-C cable, you can get one on Amazon.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
You can get your hands on this charger for just $32.
See at Amazon
RAVPower Multiple Port Portable Charger
RAVPower is another company that makes great chargers, and this is one of their highly rated ones. With 22000mAh and two USB ports for USB-C connection, it's a great option for just $42.
It's a great middle of the road charger for anyone who's looking for something that's quality but not over the top.
See at Amazon
Poweradd Pilot Power Bank
Poweradd has a great charger at a cheaper price than the other brands listed. If you're on a budget, you can get a 10000mAh charger with a USB and USB-C port for $17.
It's a great deal if you're looking to save some since you just got the Lenovo Mirage Solo.
See at Amazon
RAVPower Single Port Portable Charger
This RAVPower charger is a better option by RAVPower that's a single outlet charger. Since it's a single outlet, it has less mAh, with only 10000mAh as compared to 22000, and one USB-C output/input along with a USB port.
Although it's a single port, it still comes in at $54 which is a bit pricey.
See at Amazon
RAVPower 26,800mAh USB-C Charger
RAVPower has one more great option for those that want the absolute biggest battery they can manage. And this 26,800mAh is the largest battery capacity you can take on a commercial flight in the United States without jumping through hoops, so it's a great investment if you want a lot of capacity for your Mirage Solo and other gadgets. The battery itself can charge from the same USB-C cable you use with the Mirage Solo, or with a Micro-USB charger if you so choose. The USB-C port can output at 30W, meaning it may be powerful enough to charge your laptop as well.
RAVPower's 26,800 mAh USB-C charger is available for $82.
See at Amazon
AUKEY 20,000mAh External Charger
Another common name in the tech accessory world is AUKEY. It makes headphones, charging cables, and of course battery packs. AUKEY's 20,00mAh USB-C charger offers plenty of charge and some cool tricks. It can charge over Micro-USB, USB-C or Lightning, and it's not as bulky as other chargers, meaning it may be a better fit in your backpack or purse. The USB-C port only outputs at 15W — powerful enough for the Mirage Solo, but not enough juice to double as your laptop charger. In addition to the USB-C port, you get three USB-A ports for your other small gadgets.
AUKEY's 20,000mAh External Charger is available for $40.
See at Amazon
Which is your pick?
Which battery are you planning to use with your Mirage Solo? Let us know down below!
Updated July 2018: Added the RAVPower 26,800mAh charger and the AUKEY 20,000mAh charger.
We may earn a commission for purchases using our links. Learn more.
