Remember the days when laptops had all the ports you would ever need? Not anymore! Now you get one measly little USB-C port and may whatever gods you pray to help you should you need to connect more than that. Oh, or, you could get the Meco 7-in-1 adapter USB-C hub while it's discounted to $19.97 using the code TVXRGK98. That's the lowest we've ever seen it reach and nearly $20 off its regular cost.
Functionality
Do more with less using this 7-in-1 adapter that adds everything from an Ethernet port to an SD card reader to whatever USB-C port it's plugged into.
$19.97 $36.99 $17 off
With coupon: TVXRGK98
This hub turns your one USB-C connection into seven different ports including an RJ45 Ethernet port, two USB 3.0 ports, one 4K HDMI port, an SD card reader, a TF card reader, and a 100W USB-C charging and data port. The great thing about that last one is it means you don't have to sacrifice the functionality of the extra ports at the expense of your laptop's battery. The 4K HDMI port lets you extend your laptop's screen to a TV, larger monitor, or even a projector in 4K resolutions. That's great if you want to stream or watch movies on your laptop on a bigger display. The SD card and TF card reader can be used at the same time if you happen to have multiple formats, including SDHC, micro SD, and more. The hub is covered by a one-year warranty.
We may earn a commission for purchases using our links. Learn more.
