Using the coupon code 24WQCC01 during checkout, you can pick up one of these iClever 24W BoostCube Quick Charge 3.0 chargers for just $8.99. Since its release, this charger has bounced between $11 and $15 for the most part and the last time we saw it go under $10 was in late 2017.
If you want an affordable way to power up your devices quickly, this discounted Quick Charge 3.0 wall charger is for you. Code 24WQCC01 drops it down to the best price we've seen on it since 2017, so now's the time to grab a couple.
$8.99 $12.49 $3.50 off
If your phone supports Qualcomm Quick Charge 3.0, this plug will charge it up to four times faster than a regular AC adapter. In just 35 minutes, your device can be powered up to around 80%, so you're up and running sooner. It's also backwards-compatible with QC 2.0 and 1.0 devices, and will work with any other USB-powered device you own. The plug also has foldable pins making it ideal for travelling with. It's worth noting it doesn't come with a charging cable, so you'll want to use your existing one or pick up a spare. Users give it 4.3 stars out of 5 based on over 1,100 reviews.
We may earn a commission for purchases using our links. Learn more.
